Thermastat temp
Old 11-07-2009, 07:19 AM
boxer.fan's Avatar
Thermastat temp
I am replacing my thermastat because I think that its bad. The gauge never moved up more that a hair over cold. I grounded the sensor wire and the gauge works, checked the resistance on the sensor itself and its good so im changing the thermastat. What temp is OEM? I read the FSM and says that Opens @ 190 and the guy at the parts store gave me a 180. Should I go back and get the 190? I live in So.Cal and its my daily driver. I drive about 35miles in traffic oneway and 35 no traffic. Also he gave me the paper gasket, should I have the one that is rubber and fits around the thermastat itself???
Thanks.
Old 11-07-2009, 08:30 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
What's the vehicle you're working on? 22re? 3vze?
Old 11-07-2009, 08:37 AM
boxer.fan's Avatar
Sorry, its 22re. It has 119k and no A/C.
Old 11-07-2009, 08:56 AM
myyota's Avatar
You need the gasket that goes around the thermostat, not the paper one. If the thermostat doesn`t fix the problem the try replacing the temp gauge sending unit, they can go bad and cause the gauge to not read right, i had this happen to me and a new sending unit fixed the problem.
coryc85
12-05-2015 08:42 AM
bradahman
10-01-2015 09:24 AM
Matthew Perez
09-28-2015 05:43 PM
rmill05
09-27-2015 01:43 PM
--Oz--
09-06-2015 01:06 AM
Quick Reply: Thermastat temp
