Is there a reverse light relay on 1st gen 4Runners? - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 01-22-2012, 07:29 PM   #1
stanz's Avatar
I have an 86 4runner 22RE, 5spd. Is there a back up light relay on these? If so, where is it located?
Any pics or links also appreciated.
Thanks!
**Further clarification. My reverse lights haven't worked since I bought my runner. I've been consumed with other repairs and racing against constant rain and limited daylight in the evenings so I haven't had time to do any troubleshooting. The bulbs were good so I thought I'd just throw in a new reverse switch on the tranny tonight, that's always done the trick for me in the past. It had no effect. Still no backup lights.**
stanz is offline   Reply With Quote
Old 01-23-2012, 02:10 PM   #2
abecedarian's Avatar
No relay. There's a switch on the side of the transmission.
You replaced that, so check your wiring.
I would've suggested checking the bulbs too, but you say they're okay: you've put them in the turn signal spot, right?
You checked the grounds from the sockets?
abecedarian is offline   Reply With Quote
Old 01-23-2012, 02:30 PM   #3
OrRunner's Avatar
x2 on the wiring, also check your bulb sockets for corosion, seems to be a common issue with these older trucks!
Stanz, any luck with the speedo needle swap? Prob not on your priority list, but it will keep ya out of the rain!
OrRunner is offline   Reply With Quote
Old 01-23-2012, 05:07 PM   #4
stanz's Avatar
Thanks guys I'll try to take a look tonight.
No luck on the needle swap yet. Had to focus on other issues this weekend.
Old 02-05-2012, 12:12 AM   #5
stanz's Avatar
Resolved! Turns out the feed for the reverse lights plugs into a harness near the starter. For some reason it was unplugged. Once plugged in the lights came on.
Old 02-06-2012, 03:45 PM   #6
If you meant the plug which goes to the reverse switch on the transmission comes out of the harness near the intake and starter, yep. There's also a plug that goes to the transfer case to indicate 4WD in the same harness.
But, you figured it out.
Old 02-07-2012, 08:59 PM   #7
stanz's Avatar
Yes. that's the plug. I did see that the wiring does go on to feed the 4wd indicator as well.
Regarding that harness near the intake and starter... that receptacle there has a sibling plug joined to it. I currently don't have anything plugged into that either. I noticed that the wiring is a lower guage (thicker) with at least of the wires being black with a white stripe. Any clues as to what that's used for?
My rig has several harness plugs dangling unused under the hood that I'm curious about.
Old 02-08-2012, 06:13 PM   #8
color codes of the wires would help, photo's too.
Old 02-08-2012, 06:38 PM   #9
stanz's Avatar
Sure. Here are some pics:
Pic of the sibling plug (circled in red) alongside the reverse light and 4wd indicator harness plug:
I'm also curious about what this plug (circled red) is for on the ds inner fender well:
One last one - this is just dangling above the starter by it's wires. Clearly someone's been into it before, it has several aftermarket crimp on connectors:
Old 02-08-2012, 06:50 PM   #10
4Crawler's Avatar
Quote:
Fuel pump test jumper:
- http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Red circle:
4Crawler is offline   Reply With Quote
Old 02-08-2012, 07:12 PM   #11
stanz's Avatar
Thanks 4Crawler! One down, two more to solve.
White tire letters in, or white letters out? Scenic WonderRunner Off Topic Talk 36 03-03-2016 08:37 PM
HID Projector Retro 7x6 sealed beam Regency General Electrical & Lighting Related Topics 19 07-15-2015 04:45 PM
1st gen runner trailer wire routing toyota32 86-95 Trucks & 4Runners 6 07-06-2015 06:42 PM
88 4Runner build CJ94yota 86-95 Trucks & 4Runners (Build-Up Section) 2 07-03-2015 11:14 PM
1999 4Runner 4WD t-case issue TNRunner88 95.5-2004 Tacomas & 96-2002 4Runners 0 07-01-2015 09:00 PM
Tags
1st, 4runner, 86, 87, back, backup, gen, generation, light, lights, relay, revers, reverse, switch, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
