temperature gauge doen't work. - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-12-2007, 08:48 PM   #1 (permalink)
Unhappy temperature gauge doen't work.
I have a pick up 1994 2w. that the temperature gauge is not working I'll appreicate any info. why is not working. thank you.
nelson1969 is offline
Old 01-12-2007, 08:56 PM   #2 (permalink)
EDIT: Useless post
__________________
94' Pickup
all_terrain17 is offline
Old 01-12-2007, 09:04 PM   #3 (permalink)
The sensor for the temp gauge has one wire. It it way down the middle of the intake between the middle cylinders. It can be seen from the top.
timebandit is offline
Old 01-12-2007, 09:04 PM   #4 (permalink)
Send a message via AIM to dcg9381
That's the temp sender for the ECU.. I could be wrong here, as I know the earlier EFI system better.. On the pre 88.5 systems, the temp sensor for the gauge is in the lower plenum, middle of the plenum, next to the head on the top side... basically middle of the valve cover, go over to the passenger side of the valve cover - straight down. single wire deal. It rarely goes dead, but the wire might get unplugged.
__________________
http://www.22REturbo.net
dcg9381 is offline
Old 01-12-2007, 09:12 PM   #5 (permalink)
Probably right, dcg...Wondered what that plug was for Guess I can at least point it out...
Sorry for the misinfo
__________________
94' Pickup
Old 01-14-2007, 09:48 PM   #6 (permalink)
thank you for the info. but if wires are all plugged then the temp. sensor needs to be replaced?
Old 01-14-2007, 09:54 PM   #7 (permalink)
DudeBud's Avatar
Send a message via AIM to DudeBud Send a message via MSN to DudeBud
Quote:
Originally Posted by nelson1969 View Post
thank you for the info. but if wires are all plugged then the temp. sensor needs to be replace?
first pull the plug from the temp sender and find something to ground it out with. ground it out and turn the key on make sure the gauge goes all the way up. if it does then your wiring and gauge are fine.. swap out the temp sender. i have a weird problem with mine but its the gauge. i can tap the cluster and it will start working..
__________________
Dan
95 4runner 3vze A/T
84 4runner sr5 Ford 302
T-18 4spd yota t-case
yota front and rear both open
37X13.00 boggers
88 4runner 22re 5spd
DudeBud is offline
Old 01-15-2007, 08:11 AM   #8 (permalink)
Quote:
Don't do that unless you'd like a burnt up temperature gauge.
Ground it through a test light or some other resistor, otherwise you're not limiting the current flow in that circuit.
It probably won't short immediately, but holding it grounded is a bad idea.
__________________
dcg9381 is offline
Old 01-15-2007, 10:43 AM   #9 (permalink)
DudeBud's Avatar
its just for a sec and wont hurt the gauge..
__________________
Dan
95 4runner 3vze A/T
37X13.00 boggers
DudeBud is offline
Tags
302, 3vze, 87, burnt, f150, ford, gauge, location, replace, sender, temp, temperature, tempereture, top, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Installing a transmission temperature gauge. ManyMods 95.5-2004 Tacomas & 96-2002 4Runners 44 04-03-2007 01:45 PM
Outside Temperature Gauge black runner The Classifieds GraveYard 3 12-28-2006 02:31 PM
engine temperature gauge seems to not be working justanother4x4 95.5-2004 Tacomas & 96-2002 4Runners 1 05-08-2005 07:15 PM
temperature gauge reading ckgoobs 95.5-2004 Tacomas & 96-2002 4Runners 4 01-26-2003 07:54 AM
2009 InternetBrands, Inc.
