temperature?
Old 01-22-2009, 03:53 AM
baseballchamp157's Avatar
temperature?
Ive got a 94 pickup just rebuilt with 1500 miles on it and I finally got a temperature gauge which is good. But i was woundering about what temp. do yall run normally or should i run? I know V8s run good at 180 to 210 but
dont know about 4cylinders
Old 01-22-2009, 04:55 AM
TNRabbit's Avatar
ALL modern engines perform BEST above 185 degrees and below about 205. Lower & they are running too cool, higher & you run the risk of spot overheating. THAT SAID, water temperature is only PART of the equation; coolant flowing too quickly will give you a lower temp but hotter head temps (bad), and water flowing too slowly will run the coolant temp too high. There are a lot of variables, radiator size/fan CFM/etc., not withstanding...
Old 01-22-2009, 05:15 AM
Team420's Avatar
hmmm....nice...never thought of it like that....had no idea that coolant moving to fast would not cool the heads....
Old 01-22-2009, 05:33 AM
TNRabbit's Avatar
You're transferring heat, so there has to be a happy medium...
Old 01-22-2009, 06:55 PM
ok well i didnt know what to think about my 22re because i figured they would run alot cooler. Because i notice that my thermostat openes at 190f and then drops the temp to about 165-170 an then rises up again pretty fast and then openes again and so on an so forth. But it will open about 4 times in a matter of about 2 miles. is that bad or good?
shisha1999
03-03-2016 07:09 PM
Firefightersink15
11-23-2015 10:32 PM
rmill05
09-27-2015 01:43 PM
Boomer8404
09-20-2015 06:15 PM
anndel
09-10-2015 08:50 AM
Quick Reply: temperature?
