temp sender
Old 04-21-2008, 05:09 PM
caf325's Avatar
temp sender
Can some please help me out? A short while ago I had a problem with my temp guage going immeadiately to red after starting. Soon after it just stopped working. Today I changed my temp sender and noticed that its began doing the same thing. Also it would blow the EFI fuse everytime it went to red . I thought previously that there was a break in my o2 sensor line/harness as to why the EFI fuse would blow. But now it seems that its from the temp sender, what is the relationship of the temp sender and the EFI fuse? Please, I'm opened to all and and any suggestions.
Old 04-21-2008, 05:14 PM
TURTLE GREEN's Avatar
what are the specs on your vehicle?
Old 04-21-2008, 06:13 PM
caf325's Avatar
re: temp sender
Sorry, I have 93 22re
Old 04-21-2008, 08:57 PM
Old 04-21-2008, 09:10 PM
it looks like your efi circuit and temp sending circuit could be together or close to eachother so they could be shorting out from eachother, i guess that could be a start or maybe you have a bad thermostat and when you guage hits red line it shorts the efi circuit to ground to cut off fuel to shut the motor down? i doubt that one but its possible
pm me you realy email adress and ill send you a diagram of wut could be goin on
Old 04-22-2008, 07:07 PM
caf325's Avatar
temp sender
Here is an update, I unplugged the o2 sensor but plugged in the temp sender and after about 5 minutes of idle the efi fuse blew. However when unplugged the temp sender I was able to drive it with no problems.
Old 04-23-2008, 05:01 PM
Theres gotta be a short somewhere, thats all i could think of
Old 04-24-2008, 01:06 PM
caf325's Avatar
Smile temp sender
I found the problem!!!!!!!!!!!! It was the group of wires ( temp sender, cold start, fuel injectors wires) that rest as a bundle on top of the fuel rail. The underside of the bundle of wires had begun rubbing through the insulation. WHEW!!!!!!!!!!!!! Thanks to all that offered suggestions.
coryc85
12-05-2015 08:42 AM
bradahman
10-01-2015 09:24 AM
Matthew Perez
09-28-2015 05:43 PM
rmill05
09-27-2015 01:43 PM
--Oz--
09-06-2015 01:06 AM
Quick Reply: temp sender
