Temp Overshoot?
Old 05-09-2012, 09:59 AM
linuxrunner's Avatar
Temp Overshoot?
As soon as i turn my key and start the engine my temp goes straight to the halfway point on the gauge even if it's first start in the morning.
I know that the non dual stage t-stat's are known to cause temp gauge overshoot but i thought that usually shows as overheating after a few min run time, this is instant and never past the half way mark.
Any ideas?
Old 05-09-2012, 10:34 AM
snobdds's Avatar
It sounds like your sender is being grounded and causing the spike right off the bat. Check the wires for your temp sender and see if any of the insulation has rubbed off.
Old 05-09-2012, 10:53 AM
BMcEL's Avatar
Could also be a bad sender or loose connection on the back of the gauge cluster.
Old 05-09-2012, 01:49 PM
I will check the connector at the temp sender (the sender for the gauge is located around intake for cyl 3 correct?)
How does the temp sender work? if it's disconnected does the gauge show full cold? and if it's grounded does it show full hot?
coryc85
12-05-2015 08:42 AM
bradahman
10-01-2015 09:24 AM
Matthew Perez
09-28-2015 05:43 PM
rmill05
09-27-2015 01:43 PM
--Oz--
09-06-2015 01:06 AM
Quick Reply: Temp Overshoot?
