temp guage spikes before truck is started
Old 11-23-2010, 11:51 AM
FalseAllure's Avatar
I have a 93 pickup. Its a 3.0l v6. I blew a coolant hose behind the motor yesterday and replaced it everything seemed fine. This morning i go out to the truck and put the key in. Turned the key on and the temp gauge went all the way up. Im sure the truck wasnt hot because it sat overnight. I have no clue what it could be. Checked my connections and everything seems good. Im in need of everyones expert advice. Afraid to drive the truck. dont need it overheating
Old 11-23-2010, 12:33 PM
andykrow's Avatar
i had a bad gauge sender do this very thing. it would just pin it on all the way hot. pretty cheap to replace, at least on a 22re...
Old 11-23-2010, 02:52 PM
should i worry about driving the truck with it like that.
Old 11-23-2010, 03:04 PM
andykrow's Avatar
well... you did blow a coolant hose and if that's related to overheating...
the sender has nothing to do with engine operation but it will tell you if you're running too hot. you see where i'm going with this... and i'm no 3.0 expert but i think they're known for blowing headgaskets and you can def do that by overheating the thing. so be real real reeeeaaaaaaalllll careful if you do drive it... my advice is to replace the sender before driving it at all, just to be safe.
Old 11-23-2010, 03:10 PM
i gotcha. will fix it before driving it. i dont need it overheating. Thanks man
Old 11-23-2010, 03:11 PM
i gotcha. will fix it before driving it. i dont need it overheating. Thanks man. Do you think its possible i need a tvv or is that the same thing?
just call me smithy's Avatar
x2 on the bad sender,happened to me as well
the1998sr5
10-19-2016 12:48 PM
yourrealdad
7
07-21-2015 08:53 AM
bigblue82
10
07-06-2015 08:27 AM
Bru
06-23-2015 06:58 PM
jmc88runner
06-18-2015 03:39 PM
Quick Reply: temp guage spikes before truck is started
