| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
temp guage doesnt really move
__________________
1987 Pick Up 2.4L 4x4 2004 Rallirt 2008 Taco |
#2 (permalink) |
The Factory Service Manual has a test procedure in the "Body Electrical" (BE) section.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#3 (permalink) |
i will search the forum for the service manual..but anyone has a link to it for faster refrence?
thanks
__________________
#4 (permalink) |
Here is one:
- http://www.4x4wire.com/forums/showfl...Number=1065861
__________________
#5 (permalink) |
thanks
__________________
#6 (permalink) |
My Check engine light came on today, Got 4 flashers..i checked the code online and said something about the ECT. Coolant Temp. Where do i start to solve this problem.
My temp gauge still doesn't move like a regular temp gauge. I drove for 35 miles and the temp gauge said it was still cold. Thnx in advance fellas
__________________
#7 (permalink) |
uhhmm..firsstt off..determine whether it is your gauge..or your temperature sensor..lol then report back hahaha
__________________
FOR SALE 1986 Ext. Cab 4x4, rebuilt 22R, 5spd, 31x10.50 X-Terrains FOR SALE 1992 SR5 FO RUNNA V6, 5 speed, 4in. trail-master lift, 33x12.50 BFG muds, 4.56 gears!!! and an IMMACULATE interior..yes..you should be jealous "Its still a toyota man.. Dont deprive it of its capabilities.." "If you can read english, Thank a teacher...If you can speak it, Thank a soldier!!" Kelli Ruark-2009 |
#8 (permalink) |
To test your dash temp gauge, pull the wire off your temp sender and ground it. Turn the key on, and the gauge should go all the way over to "hot."
![]() If the gauge is OK, then your engine is running too cold. Probable cause is a stuck open thermostat. |
#9 (permalink) |
OK, I was about to post the same question but did the search first and found this. If the gauge is good with grounding the wire and it went to HOT could it be the sending unit? Checking the unit would be a check with ohm meter for resistance? My Cat is bad and tailpipe is black with rich smell so this could fix it. Thanks.
#10 (permalink) |
Yep, sender is a variable resistance device. I think the FSM lists some resistance vs. temperature values.
__________________
#11 (permalink) |
Okay so i grounded the Temp Sensor and the gauge did not move at all, when it is not grounded it moves like 3mm
__________________
#12 (permalink) | |
Quote:
If the gauge checks out, then the sender that you pulled the wire off is bad, or the thermostat is likely stuck open. Since you're getting a code for coolant temperature, the most likely problem is the thermostat. |
