tell me where these plugs up to
Old 10-02-2010, 01:52 PM
thisgsx's Avatar
can someone tell me where these go?
the hose that is sticking out. it is on the front passenger side. it looks like it's coming out from the blower from inside the truck. water drips from it as you can see in the picture. is it suppose to be like that? for the life of me i can't find where this plugs up to.
and now i have this connector that i can't figure out where it goes. it is part of the harness that connects to the fuel injectors.
thanks.
Old 10-02-2010, 02:03 PM
nate9915's Avatar
the first picture is from the AC it is suppose to drip it doesnt connect to anything its a drain. if you ever have your ac leaking water on the passanger floor board its because it is plugged so if its dripping water thats good im not sure about the second picture
Old 10-02-2010, 03:46 PM
wii_tarded's Avatar
what color are the wires that go to that plug?
Old 10-02-2010, 04:40 PM
wii_tarded's Avatar
If the wire is yellow with a blue stripe, it goes to your oil pressure sending unit down on the side of the block under your alternator.
Old 10-03-2010, 05:29 PM
thisgsx's Avatar
alright, i figured where it goes. it plugs up to one of the connectors down by the oil pan. the wires are green and yellow. thanks guys.
Blamalam
03-12-2022 07:34 AM
old87yota
10-25-2015 02:15 PM
80Truck
07-24-2015 03:12 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
msane99
07-17-2015 10:13 AM
Quick Reply: tell me where these plugs up to
