Tech help
Tech help
I am needing some technical advice from someone. I have a 92 Toyota 4Runner with the V6. Cranks and runs beautifully in park and neutral at both cold temp and at operating temp. Will shift fine until it gets to operating temp., then kills the motor. Anyone got any ideas?? Thanks in advance.
I don't think that the converter will go into lock-up until operating temp is reached, so you have relatively normal function until then.
After lock-up it may not unlock correctly hence: engine stalls.
The fact that this prob appeared after tranny solenoid work may be significant.
WTB[SouthEast]: Need heater control valve for 85 4 runner
twasabug
10-30-2015 11:11 PM
yota884huntn2
10-27-2015 12:16 PM
Notabout2try
10-13-2015 11:48 PM
