Tdc
Tdc
I have a 1991 toyota pickup with 22RE engine, EFI, automatic tranny. Is TDC 0 or 5 degrees and do you know the page in the FSM that mentions this? Thanks
Ignition timing is 5 degrees BTDC at idle with terminals TE1 and E1 connected. The distributor is installed with the engine a 5 degrees BTDC as well.
The ignition section of the FSM mentions this.
http://personal.utulsa.edu/~nathan-b.../5distribu.pdf
Staff
A Timing Video I like Better. Set Crankshaft pulley to 5 degrees.
Timing Video
http://www.youtube.com/watch?v=9qEQM...ature=youtu.be
Easy way to install distributor on Youtube.
Timing Video
Jason Webber
09-02-2015 03:30 AM
cgilley
07-25-2015 10:55 PM
