tc cover question
Old 03-18-2011, 11:09 AM
bspeth's Avatar
tc cover question
if i had to loosen the head bolts to get some play in order to replace tc cover with head on can I just add a couple pound of torque when retightening them,say 60lbs instead of 58? if this doesnt work what will be the first sign? thanks.
Old 03-18-2011, 11:20 AM
justin_4runner's Avatar
not the best idea to loosen the head and try to re tighten, do the the oil pan instead of the head, to get the space u need if u look around there are a couple threads on doing it that way. the head gasket will leak from the water ports down the block or into the oil.
Old 03-18-2011, 01:02 PM
shaunneuhaus95's Avatar
i concur
Old 03-18-2011, 02:02 PM
bspeth's Avatar
the gasket is brand new if that makes a difference.Yea I cracked the tc cover tightening the head to tc cover bolt and got a leak.
Old 03-18-2011, 02:13 PM
iamsuperbleeder's Avatar
doesn't make a difference if it's a day old. if the head's been torqued down, and you loosen the head bolts, there's probably about a 75% chance it'll spring a leak
they're a one time thing; once you torque it down, if you have to loosen it back up, you have to replace it
Old 03-18-2011, 03:04 PM
xxxtreme22r's Avatar
Well I have seen people on here loosen them to change cams and ratchet strap the head down and have had no problems, but for what he wants to do it's not a good thing. I am sure he wants to lift the head a little to get the cover off. Which is not needed to do.
Old 03-18-2011, 06:33 PM
bspeth's Avatar
will it leak right away if at all or will it always be prone to failure,its already back together.
Old 03-18-2011, 06:52 PM
it might hold for a little and then one day go or it could just go from the start. i guess since its together keep an eye on it extra good and watch your water level. and keep an eye on it.
Old 03-18-2011, 06:55 PM
Why ask if it's bad to do something and do it anyway?
Old 03-18-2011, 07:30 PM
bspeth's Avatar
I had already put it back together when I wrote the post,I just wanted to know what my expectations should be.I know I may have screwed myself,(I know I should leave that to my wife)but I am very new at wrenching and I am still learning,even if it is the hard way.Should have asked the question first
the1998sr5
15
07-14-2020 08:35 PM
coleypull15
11-03-2015 07:41 AM
thefishguy77
07-30-2015 10:59 AM
cgilley
07-25-2015 10:55 PM
icentropy
07-09-2015 02:12 PM
Quick Reply: tc cover question
