tapping noise in 22re
Old 02-21-2010, 12:09 PM
87toyy's Avatar
i got a couple trucks cheap for parts,buddy thought the rear main seal was gone in the one with the good motor. i found out it was only the valve cover leaking. the motor runs really well but it has a tapping noise in the top.its definately coming from under the valve cover. it doesnt seem to get any louder with reving it just a steady tap all the time. any ideas?are the valves adjustable on these? i plan on putting the motor in my good pickup if its nothing major.
Old 02-22-2010, 01:21 PM
Flash319's Avatar
Prob the timing chain tensioner. These engines are always a bit tappy but if it is sounding kind of like a diesel it is the tensioner going. Change it or you will have bigger problems.
Old 02-22-2010, 01:25 PM
jaredbishop's Avatar
I had a tapping noise 2 hours latter I figured out that it was a socket that had fallen down near the power steering pulley.
Old 02-22-2010, 02:30 PM
87toyy's Avatar
i checked the valves today and one needed to be adjusted. still a little noise in it but i dont think its the timing chain tensioner. sounds more at the back of the motor. some of the valves were tight i couldnt get the right feeler guage under them but didnt want to loosen them up. could this cause noise to if they are to tight?
Old 02-22-2010, 02:35 PM
87toyy's Avatar
i also noitced the 2 hoses going into the valve cover and the whole top of the inside of the valve cover had watery oil on it. is this normal? i have never had any signs of water in the oil or anything just seems to be sitting on the cover and end of the hoses going inot it. jsut want to be sure this motor is good before i put it in my other truck.
Old 02-22-2010, 02:44 PM
xxxtreme22r's Avatar
mine has that moisture too around the oil cap, pcv and breather tube. 1000 miles on rebuilt motor. I guess these motors are prone to that?
Old 02-24-2010, 11:38 PM
abecedarian's Avatar
I've said it before, and will say it again: "meh"... If you have checked everything from the tensioner to the guides, have great oil pressure, and you've adjusted the valves to the tightest end of the specs (~.007 intake, .010-.011 exhaust) and you still get taps from the valves... face up: the rocker arm bushings / rocker shafts are worn. There isn't any amount of adjustment you can make to cause those to go quiet.
Old 02-25-2010, 03:12 AM
87toyy's Avatar
i was told the specs were 008 intake and 012 exhaust.so should i go to 007 and 010-011?
Old 02-25-2010, 05:45 AM
Flash319's Avatar
The watery goop is from the PCV system. Fresh air is drawn through the valve cover and fresh air has moisture in it.
As for the tapping...just turn the radio up.
mskalmus
05-28-2017 07:51 AM
coleypull15
11-03-2015 07:41 AM
PlayAwhile
07-20-2015 11:36 AM
Jeffreynmandy
07-18-2015 08:26 AM
razorman8669
07-12-2015 12:13 PM
Quick Reply: tapping noise in 22re
