Taking grille off/headlight replacement
Took out the side lights, I got off all the top clips, and it seems like I have all the clips on the bottom either out or broken...
The grille will not budge, at least from the bottom. I have the replacement headlights, just can't get the old ones out.
What a pain.
What a pain.
On my '85 there was a bracket that extended from the bottom of the grille down to the cross member.
Pics would help a lot.
Fink
I don't have to remove my entire grill just to replace the bulbs
it's a tight fit with a screwdriver yeah, but it can be done without removing all the crapola
I finally just invested in some H4 conversion lights so much easier just to pull the bulbs out from behind
you have to take the bumper off too!!, Yeah its that stupid!! there is a part of the grill that the bumper holds to keep it from moving...you can always cut it off to make it easier, or get a new bumper like I did (even though now my winch is in the way!!
According to the owners manual, there are the clips on the along the top and the bottom. That is it. Doesn't really seem to be the case. Where do I get the "retrofit" H4? Do those just slide into place, like replacements are supposed to? Or is ther grille modifications to do?
Search for H4 replacements on here, there is a big thread about it. They are on E-bay (cheaper) or you can get the Hella kit. I bought the DOT legal lights and did not see as big an improvement as others. Read the thread, it has all of the info in it. Ah heck, here is the link:
https://www.yotatech.com/forums/f116...talled-159609/
I decided to for-go taking the grille off. I was able to get 3 of 4 of the little retaining screws off the bracket that holds the headlight in place. With a little nudging, the screwdriver fits. But the 4th one is friggin rusted/something in place and it doesn't budge. Too small of a fit for a vice grip or pliers. I give up for tonight. Going to try to drill out the screw tomorrow.
Also the part about the screw on the bottom part (which is what I was trying to explain about the bracket).
I would soak it in Liquid Wrench or PB Blaster all night, I bet you'll be able to get it out without drilling it.
Fink
I thought it was a joke, about the bumper. I cannot, for some stupid reason, find any other screws holding the grille on. Now if I have to take off the bumper, who knows what that will lead to...
Well, I was able to bend/move/adjust each side of the grille enough to get at the 4 light bracket screws. Not easy, but replaced both headlights. Man, I hope the newer Toyotas do not have this issue (that is if I can ever afford one).
Thanks for all the insight.
I replaced the sealed beam lights with the Hella H4 conversion kit and would recommend it 100% to anyone looking for an upgrade. Yes, it's pricey, but I like being able to see.
Is it just me that thinks the grill is easy to remove?
There are little tabs on the edge of each clip, just push them, in with your finger and they release.
remove side markers and just pull the grill out. My oem bumper only got in the way once it was bent.
Hella h4 e-code lenses are what you want to buy. They will blow the doors of anyother light available, with the exception of HID's.
x2 Rob. Cost me $140 for everything shipped up to me. But heck it was worth it, for something im going to use every day... its worth the investment.
I recently cracked my passengerside lense Nice crack, light still works %100. Not sure if im going to replace it yet
Did you guys do the Hella H4 upgrade with the 4crawler wiring "upgrade"? Or just the Hella kit....
I may invest $140 since the stock headlights do suck, but just wanted to make sure there were no other factors involved. Thanks
"My oem bumper only got in the way once it was bent."
Well, I guess that might have been half my problem. The lower part of the bumper (not the upper chrome) is bent to heck. Oh well, hopefully they will last a few years.
Bill
Bill
Click on my cardomain page to see light output pictures. My lights overshadow thoes of newer cars.
Might be your problem. Mine was bent up so it pinched the grill in...
I just went with the Hella kit and a set of GE Nighthawks. The difference between the old and new is amazing. Even lighting all across the road on low beam, and the highbeams are excellent.
I took the grille off my '88 in about 5 min. The top clips and screws are easy, but you might need a long screw driver to get the clips on the bottom. You must be careful not to let the clips slip back in, because they do so very easily and it gets frustrating. Once the clips are all undone, you have to wiggle the grille out, it doesn't pull straight out. And just extra: when your putting the grille back on, take the clips from the truck, snap the correct end into the grille, and then put the grille on. Its much easier that way. Hope to have helped. (:
MMA_Alex
25
04-18-2017 05:07 AM
WTB[WestCanada]: 1989 4runner stock front bumper and other items
lledwod
08-30-2016 01:03 PM
TURBOrunnerNM
07-22-2015 11:01 AM
skoti89
07-08-2015 12:05 AM
Jnkml
07-06-2015 01:20 PM
