taking battery cable off
Old 04-15-2015, 04:35 PM
50kta's Avatar
I had the truck running other day and the altinator has what sounds like a "dry bushing" so I took the negative batt. cable off bettery and truck died. does this mean alt is bad?
its a 1990 3.0, 5-speed truck
Old 04-15-2015, 05:19 PM
muddpigg's Avatar
I don't know why this could possibly even sound like a good idea. Before you do any more work or trouble shooting of your electrical system I recommend you do a google search for automotive charging system basis before you hurt yourself or damage your ride.
Old 04-15-2015, 06:31 PM
shadowbirdie's Avatar
Ya, do some research please
They're bearings, not bushings and disconnecting the negative cable, or the other can easily blow up your ignitor module, a very expensive error.
Old 04-15-2015, 11:23 PM
wyoming9's Avatar
Red face
For what ever reason back in the day early Sixties when ignition systems and charging systems were quite simple .
This might even have been a holdover from the days vehicles had generators
People unable to figure out how to use a simple meter thought pulling a negative battery cable off was a good way to test alternator output.
Things were simple enough things didn`t get fried although quite a few batteries did explode.
It means time to get a multimeter !!
Old 04-16-2015, 07:55 AM
50kta's Avatar
wow thanks for heads up. im just realy old school on doing that to the old cars.
Liadrin
04-25-2022 02:54 PM
jasonty
41
12-23-2018 01:00 PM
v_man
07-23-2015 04:01 PM
shar
07-09-2015 12:38 PM
skoti89
07-08-2015 12:05 AM
Quick Reply: taking battery cable off
