Tacoma E-locker in toyota 4cyl rear end?
Been searching and all I've really found is wiring harness' for the swap and people putting whole thirds into newer 4runner rear ends. Is there a way to put the tacoma locker into the older (92) rear end? I have a spare third that I want to put it into and ill swap it in when it's finished.
I have an E-locker in an 88 4cyl 4x4 rear end and about to do one in my 84 4x4 front end
here is a good thread
https://www.yotatech.com/forums/f116...-build-183550/
ok, so you take the whole third, and drill the housing. i understand it now. so for a harness, i can just shoot a pm to 12voltguy or go through marlin. then it basically is just on a switch?
Please realize your question gets asked at least once a week. It gets old having to repeat the same info over and over and over when 98% of the time the question can be added onto an existing thread so it doesn't clutter up the board.
Just take your time with the taps and drill to make sure your new studs line up straight.
My new (assumed) job is to point out that if you search on Google for something like "elocker 4cyl rear end yotatech f116" you will get much better results. The "f116" limits your results to this forum.
FS[SouthCent]: Toyota Trail Gear 5.29 Ring and pinion x2 NEW
YotaLogic
12
11-17-2015 06:27 AM
red88toy
11
08-03-2015 07:47 PM
bigblue82
10
07-06-2015 08:27 AM
