YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 10-11-2008, 05:26 PM   #1 (permalink)
AZ89LONGBED's Avatar
Taco Axle Swap??????
Well, I am taking a break for today from assembling my LCE & EB motor, and I have been dreaming a bit on e-locker swaps.
Could I Swap in an entire Tacoma e-locker rear axle, run wheel spacers (up front), and be ok? Would the overal wider rear Taco rear end affect handling if I didn't put spacers on?
Just a few ravings of a mad man.
On another note, I have pulled out the old motor & re-installed new mounts, assembled the motor, and will drop it in tomorrow! Woot!
AZ89LONGBED is offline
Sponsored Links
To remove this ad, register today!
Old 10-12-2008, 02:46 AM   #2 (permalink)
Matt16's Avatar
The Tacoma axle is wider than the pre-95 axle, but yes you can do so. It's probably easier just to install the e-locker third after modifying you current housing. Here's a link with the info you need to retrofit a e-locker into your current axle housing.
http://www.4x4wire.com/toyota/tech/electric_locker/
__________________
1990 Toyota 4Runner 22RE 5spd
Rear Aussie Locker [click here for the review] *Nokian Vativa A/T tires* OME suspension* York OBA* pretty much stock.
Quote:
Originally Posted by DaveInDenver View Post
Yeah, I do think it's sort of funny. Can't you see a roomful of Toyota engineers looking at a relay rod, scratching their heads and saying 'Hmmm, this part wore out after 200,000 miles and 16 years, this is just unacceptable.'
Toyota FAQ link
More info on 4Runners
- awesome resources
Matt16 is online now
Old 10-13-2008, 12:47 PM   #3 (permalink)
Since I will be doing this swap in my driveway just replacing the entire axel housing would be easier for me, vs welding & grinding, etc.
The spring perches should align according to info I searched on here, but the driveshaft flange compatibility raises concern. Do I need to do some drilling or need machine work to make my driveline compatible?
__________________
89 Longbed PU with lots of AZ pinstriping
My DD build begins with an LCE shortblock, EB street/RV head & 268 cam, LCE header, Magnaflow cat, LCE cat-back & some TreadWright 235-75R15. The future: E-locker(s), 33x10.5's or LT265`s, t-case gears, BJ spacers, OBA of some sort, sliders, skids...
Old 10-13-2008, 01:06 PM   #4 (permalink)
ocdropzone's Avatar
Order a Triple Drilled Flange from some like Brian at Wab-Fab.org
that should fix your drive line capatibility question
axle width:
Toyota Rear Axle Widths:
55" wide, '79-85 4wd trucks/4runners - 6 Lug
58" wide, '86-95 4wd trucks/4runners - 6 Lug
56" wide, '79-95 2wd Trucks - 5 Lug
60.75" wide, '95.5-'04Tacomas/4runners
wheel spacers will only be needed up front, 1.25" spacers would be the best IMO...
Is this a 2WD or did you get a match gear set for the front too?
__________________
~Robb
'81 Trekker SR5 B4Runner Build
'89 Tercel Project POS Gas Saver
TREKKER Forum
LINK TO ONLINE FACTORY SERVICE MANUALS
All Toyota Website Search Engine
Wheel Responsibly, Don't screw it up for others...
ocdropzone is offline
Old 10-13-2008, 01:18 PM   #5 (permalink)
I'll get a matching front 3rd, did some of those tacos come with the 4.56 or only the 4.30??
__________________
Old 10-13-2008, 01:27 PM   #6 (permalink)
ocdropzone's Avatar
Not sure about the Taco Rations, thought I had a link book marked but not finding it. Personally I would pop the third out to verify the Ring gear tooth count just because it would suck to buy another third member off somewhere like craigslist that you can't return...I had the elocker on my old (and missed) '05 Tacoma, be sure to get an e-locker skid plate for it, about $50-75..very cheap protection for the locker motor.
How about the wiring for the E-locker?
ORS has a good one (down towards the bottom of the page)
http://www.offroadsolutions.com/harnesses.html
__________________
~Robb
TREKKER Forum
Old 10-13-2008, 02:28 PM   #7 (permalink)
olharleyman's Avatar
Good info I was thinking the same thing for my sas 93runner but will the spacer work for the 85 solid axle?
__________________
1990 4 runner 5 Speed
Pro Comp Stage II 4" Lift 6" coils rear
Aussie Locker front
5.29's Front And Rear
35 x 12.5 x 15 MT's Micky Thompson Classic II Wheels
Super Charged 3.4 on the way
1993 SAS 4runner 22re 5 speed
4" front 5"rear
5.29's
35 x 12.5 BFG KM'S
Dick cepek DC 1's
1955 Harley Davidson Springer
Stock 1955 Hardtail Frame
4 Speed
Kick Start Only
Streached 5.5 gal. tanks
16" Ape Hangers
3" open primary
1998 Harley Custom Dresser
107 rwhp
139 ft.lbs.trq.
olharleyman is offline
Old 10-13-2008, 05:16 PM   #8 (permalink)
OCD-- What is the price on that flange?
ETA: Nevermind, I found the part on wabbitt-ito's website.
__________________
Old 10-13-2008, 07:29 PM   #9 (permalink)
RatLabGuy's Avatar
I'm alsmot positive that the spring perches are NOT in the same place, at least I know thsi to be the case w/ the 80s Runners. i just installed an E-locker into my '89 (gen 1) Runner, and did not do whole axle swap for this very reason. Plus, I wanted 5.29 gears so it needed to come out anyway.
if thsi is teh case, then the total; amount of work is more than just swapping teh third. Keep in mind also the Taco rear is intended for 16" wheels,.don't think 15" will fir, so unless you oddly have 16s already, you'll have to change wheels. Plus you'll have to re-do all teh brake plumbing so the new stuff liens up w/ old; e-brake line, etc etc. But... couldn't you get rear disc brakes this way? that's a bonus.
The axle mods really are pretty minor. I did all the mods in a Saturday. What took longer was doing the wiring... lots of good writeups on it though.
IDK about you, but moving around an axle is a serious pain. I chose to leave teh axle attached and do all te hwork under my truck. The key is, get that sucker jacked up as high as you possibly can (e.g., 12 ton jackstands) so there's enough too to sit up under it; then it's easy doing the welding, drilling, etc.
The welding literally took 5 min;a few passes on 2 spots. Grinding for about 90 seconds. More time spent on prepping, climbing in/out etc than actually doing anything. You really only have to "move" (e.g., drill/tap) 2 of the holes (the ones on the side for the long studs).
__________________
With 200+ billion electrical parts, the worlds most impressive machine is inside your own head.
RatLabGuy is offline
Old 10-13-2008, 08:13 PM   #10 (permalink)
tc
tc's Avatar
Ebrake is on the other side IIRC, perches don't line up, wider width, all kinds of stuff to fab to do an axle swap compared to drilling a couple holes for a thirdmember swap ... no brainer to me.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is online now
Old 10-14-2008, 10:57 AM   #11 (permalink)
yeahp, that sounds like the 3rd swap is easier all things considered. But dang, it sure sounds like an easy idea, and it did say somewhere that I searched on here that spring mounts did line up... Anyways, thanks for all of your input.
__________________
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Axle Swap - Land Cruiser axle in 4runner?? Anyone? montypower 86-95 Trucks & 4Runners 17 05-03-2008 03:45 PM
Rear Axle Swap 99 taco justmatt83 86-95 Trucks & 4Runners 2 05-30-2007 02:46 PM
Taco Rear axle on 4-runner? snwbdr 95.5-2004 Tacomas & 96-2002 4Runners 18 05-11-2006 02:59 PM
Axle/Gear Swap Help: Will a '94 Auto-V6 4x4 axle swap into my '90 22RE-5spd 4x4? Justin311 86-95 Trucks & 4Runners 15 04-15-2006 12:18 AM
4Runner ABS rear axle vs. Taco no ABS axle p1michaud 95.5-2004 Tacomas & 96-2002 4Runners 16 08-22-2004 03:39 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
