Tabs from front faceplate to hood
Old 03-18-2013, 04:55 PM
Edionne13's Avatar
Okay so I don't know what they are called but I'm in need of those Tabs that make the Toyota faceplate stay on. I broke 4 and there's a 91 4 runner same tabs used?
1993 pickup
Old 03-18-2013, 05:54 PM
Co_94_PU's Avatar
No idea what those are, I pretty much call all those dodad type things panel or body clips. Might be able to dig it up on the parts sites or http://www.utoyot8.com/
http://www.utoyot8.com/Picture.aspx?...&ppName=MBV853
Doesn't say, but input the part number at the parts site and it should turn something up.
Old 03-19-2013, 10:00 AM
highonpottery's Avatar
zip ties? did you break the plastic tabs on the grille, or did you break the body clips? if you broke the tabs, you're pretty much SOL and would have to epoxy them back on or buy a replacement grille. if it's the tabs, any dealership or even auto parts store should have them in stock.
Old 03-19-2013, 07:55 PM
Edionne13's Avatar
I have broken the tabs. Can I grab them off 91 4runner though I have 93 pickup?
Old 03-19-2013, 09:39 PM
Co_94_PU's Avatar
This one shows the part..
http://toyota-parts.toyotapart.com/s...-12040&x=0&y=0
This one shows the donors.
http://www.toyotapartszone.com/Page_...er=90467-12040
I don't recommend using zip ties, they will eventually dry up break and the grille fall off. Use bailing wire or similar. Do as I say not as I do, mines on with zip ties still thanks for the reminder I ment to swap those out
Old 03-19-2013, 11:01 PM
wyoming9's Avatar
Red face
Black zip ties work just fine.
I change mine every once in a while if I remember.
Old 03-20-2013, 02:52 AM
Edionne13's Avatar
Thanks guys zip ties it is
Old 03-20-2013, 05:24 AM
Edionne13's Avatar
westonian18
05-01-2020 06:38 AM
jasonty
41
12-23-2018 01:00 PM
88sasturbotoy
08-11-2015 01:56 AM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
dropzone
07-16-2015 02:00 PM
Quick Reply: Tabs from front faceplate to hood
