| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
A/T oil temp, Charge Light, and brake light come on
__________________
86 Runner with rebuilt 22re and 5 speed swap |
#2 (permalink) | |
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
let's start by saying starter issues and charging system issues are sometimes not caused by the same thing, but can also be caused by the same problem. You could have a perfectly well charged battery and have starter issues, and you could also just as well have battery in perfect condition which the charging system cannot keep charged.
so, let's separate those for the moment.... considering the alternator output is rpm related, I'll say you have a likely culprit right there, between battery and ground wiring. and you say you just did a 5sp swap, so grounds again come into play.
__________________
Quote:
Insomnia: it's a way of life.
#3 (permalink) |
your alternator is bad... That is what the combination of lights means. If you are having trouble starting the truck, it's because the battery isn't holding enough of a charge to turn the starter.
__________________
Obama is an acronym. OBAMA = One Big Ass Mistake, America |
#4 (permalink) | ||
Quote:
... and the truck just had a swap from auto to 5sp. Any thought on that?
__________________
#5 (permalink) |
Could the problem be if my positive battery terminal was touching the hood? My mechanic put new ones on there and it has a tall wingnut and it looks like its been hitting the hood off and on. Ill try running it with the hood up and see if there is any difference. Nope that didn't do it nevermind.
__________________
86 Runner with rebuilt 22re and 5 speed swap Last edited by Luvmeye22re; 11-10-2008 at 02:16 PM. |
#6 (permalink) | |
Staff
Quote:
__________________
Tacoma miniheader install kit Now available! Click here for ordering information Need that hard to find part? Nix99 Used Toyota and Lexus parts! |
#7 (permalink) |
Well I replaced the wingnut with a regular nut and nothings touching the hood anymore. I don't think that was the problem but I did it anyway. I pulled my alternator (the plug came out way too easy) and went to have it tested at checker and they said that my original Toyota alternator was doing better than their brand new one lol. I went back to my work and looked in the plug and the inside of it was full of a brown chunky substance so I blasted it with about 1/3 of a can of electrical cleaner and realized that the o-ring in side of it was really worn out and wasn't allowing the plug to go into the alternator completely. Turned out to be an easy fix.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Charge light and Brake light on after Alt and Reg Swap | jasontbird | Pre 84 Trucks | 18 | 04-29-2009 09:41 AM |
| charge light and brake light???? | Junkers88 | 86-95 Trucks & 4Runners | 12 | 07-07-2008 09:01 AM |
| Charge, brake and A/T Oil Temp Light on | 4everunner | 86-95 Trucks & 4Runners | 3 | 09-30-2007 02:07 PM |
| A/T Oil Temp, Brake, Charge Light All On...............HELP!!! | mattk | 86-95 Trucks & 4Runners | 6 | 08-07-2007 11:21 AM |
| Charge Light/ Oil Light | 87toylet | 86-95 Trucks & 4Runners | 6 | 12-09-2006 12:18 AM |
