T-Chain Timing Marks Not Normal
Old 10-20-2009, 09:32 AM
TORTIS's Avatar
I have replaced 5-6 timing chains, but this one is not normal.
The crank sprocket dot is in the 6 o'clock position, but the cam sprocket is one, maybe, two tooths off to the left.
Could they have degreed the cam in and this is why it is not at the 12 o'clock position?
Should I put it in the 12 o'clock position, and install as normal.
Made sure nothing was moved during the teardown.
Old 10-20-2009, 09:37 AM
874runnersr5's Avatar
I dont think there is any way to change the degree on the stock cam no?
Old 10-20-2009, 10:38 AM
TORTIS's Avatar
I went ahead and set both sprockets at 12 oclock.
Old 10-20-2009, 10:41 AM
Yea, i guess just rotate the engine with a socket to make sure everything is good. ie at tdc valves that are suppose to be closed are, vise versa
09-04-2015 09:27 AM
razorman8669
07-12-2015 12:13 PM
smiley52
07-11-2015 05:16 AM
wilbertd
07-06-2015 07:39 AM
Quick Reply: T-Chain Timing Marks Not Normal
