T-Bar mess up ... Help
Old 05-12-2008, 06:28 AM
Old Man's Avatar
I was going to to reinstall my stock t-bars instead of the HD's I am currently running. When I picked up my old t-bars I cannot find my markings. Is there any way to tell the difference between right and left. I did notice the head of one of the bars has a little more tapering than the others.
Old 05-12-2008, 06:55 AM
mt_goat's Avatar
check this out;
http://personal.utulsa.edu/~nathan-b...29torsionb.pdf
You might have to clean them up to see the marks.
Old 05-12-2008, 06:56 AM
abecedarian's Avatar
There should be markings on the end of the torsion bars. If they're dirty spray them up with throttle body cleaner or something similar.
Old 05-12-2008, 06:57 AM
mt_goat's Avatar
Beat ya by a second
Old 05-12-2008, 07:10 AM
uh uh... you internet is just faster than mine.
Old 05-12-2008, 07:17 AM
mt_goat's Avatar
Yeah just switched to Cox cable, much better than DSL.
Old 05-12-2008, 07:34 AM
Old Man's Avatar
I have already cleaned the heads. There are 4 dash marks on each one and arrow heads in the center pointing out. But no L or R.
Old 05-12-2008, 07:39 AM
DaveInDenver's Avatar
If you can see the arrows, that tells you which side. The arrows point out.
Old 05-12-2008, 07:56 AM
Old Man's Avatar
My arrow heads do not look like that. they are on the enter circle pointing to the outside edge of the bar. (Man I wished my camera worked.)
Old 05-12-2008, 08:06 AM
mt_goat's Avatar
Here's what I'd do, remove one side of the bars you have in there now (Downey right?) and lay it next to the old bars and compare the indexing splines. You should be able to see the clocking pattern differences of right vs left. Might help you see it if you mark the indexing spline on each end with paint or something. The indexing splines will be clocked different.
I'd go look at my old OEM bars but they are up in the attic.
Old 05-12-2008, 08:37 AM
Old Man's Avatar
I removed them a few minutes ago. I can clearly see a pattern difference between the two stocks, but I can seen no difference between the downey's. The downey's are clearly marked L and R on there heads. I am now looking at it through a magnifying glass, but I wish I had a micrometer. By the way thanks for all your help so far.
Old 05-12-2008, 09:07 AM
mt_goat's Avatar
Interesting, I guess I didn't pay that much attention when I installed my Downey bars.
Old 05-13-2008, 05:22 AM
Old Man's Avatar
you were right
You were right, I had tunnel vision real bad. This worked thanks for the help.
Old 05-13-2008, 05:46 AM
mt_goat's Avatar
Great
ktm192k
10-01-2015 08:47 AM
hiluxinargentina
09-30-2015 11:12 PM
beltcutter
09-30-2015 06:14 AM
EVars
09-29-2015 02:06 PM
punks_is_4x4
09-19-2015 05:52 AM
Quick Reply: T-Bar mess up ... Help
