YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-17-2008, 09:17 PM   #1 (permalink)
taikowaza's Avatar
synthetic brake fluid for 2nd gen
will be getting the marlin brake pads this week and thanks to a lot of good advice I will not be spending the big bucks on vented slotted rotors, braided brake lines, new shoes and drums etc. I learned that stock 4runner brakes are pretty good, and that rear shoes don't really need replacing all that often.
I also learned that a brake fluid flush can do wonders for pedal feel.
my question is about the best brake fluid to use for a complete flush. going with synthetic redline engine oil and royal purple xfer case and diff fluid was great and I am glad. I'm not finding a lot of information about synthetic brake fluid though, except an old confusing post about DOT 4 and 5 and 5.1 that I did not understand. Thanks for the name of the best brake fluid and how much I'll need, I'll buy it this week!
__________________
'92 4runner,Thorley Ceramic Headers,Stan's Custom Exhaust,OME Suspension,Downey HD Coils,Marlin HD Clutch,PIAA520s,24/30"Magnaflow Muff/Cat,Warn Prem Hubs,BudBuilt IFS Skid+Xmbr,Sonoran Truss,Odyssey bat,33x10.5 BFG A/T,ISR Mod,Boyle's HO Alternator,Powerlock,Rustbuster,Dual 4.88 Truetracs,LCE bored TB,Weasy Cams,NWMP Xtnd Range Tank
taikowaza is offline
Sponsored Links
To remove this ad, register today!
Old 05-17-2008, 09:25 PM   #2 (permalink)
taikowaza's Avatar
hmmm just did some searching outside of YT and discovered that synthetic brake fluid might not be a good idea after all, something about 'chunking' and lumixing with old fluid etc...
although some people recommended very high quality fluid with high boiling points.
(example)
You might want to do some research before you go with a synthetic! I remember something about synthetics. Dont think you can use it!
I used 2+2 Super High Performance 450 F fluid. It works VERY VERY well! I know this because I did not get any brake fade for the first time while towing my 5,300 pound boat!
You dont really need to go synthetics! Just use a very high quality fluid. Change it every year or two and you'll be fine.
__________________
Old 05-17-2008, 09:29 PM   #3 (permalink)
CJM
CJM's Avatar
Always used plain old DOT 3 or 4 fluid depending on the car at our shop, no issues.
__________________
96' T100 SR5 4x4, ISR mod, Custom ABS snorkel, KC 57's Hella optilux el cheapo backup lights. Cobra 19III CB, Firestick 4ft antenna, Bilstein shocks. Currently needing tires, rims, axle shafts, etc. PM me if you have axle shafts!!
Be polite. Be professional. But, have a plan to kill everyone you meet.
CJM is offline
Old 05-17-2008, 09:33 PM   #4 (permalink)
86tuning's Avatar
For the most part, regular DOT3 will work fine fine fine for your application.
On a track car (read: racetrack speeds and excessive brake usage and temperatures) you could benefit from a higher temp brake fluid. DOT4 or any of the Super DOT4 brake fluids will work fine. The creme de la creme of super DOT4 fluids is Motul RBF600 which stands for racing brake fluid, 600F boiling point.
On my track car (modified ae86 corolla) I use either RBF600 or DOT5.1 which are both compatible with regular DOT3 and DOT4.
On my truck, I use Toyota DOT3 which is more than sufficient, considering that most of the time the brakes are being used it's going 2mph. Sometimes when I'm driving on the freeway I'll be doing 55mph and a few moderate stops don't even come close to taxing the DOT3 brake fluid boiling point.
The real skinny with brake fluid is that the moisture capacity of a brake fluid effectively decreases with temperature rating increase. So for the most part a DOT4 fluid will hold less moisture than a DOT3. This is not a good thing. On a racecar, it's not a big deal, we do brake maintenance before and after (and sometimes during!) a track session. On a trail rig, you're not likely to do brake maintenance more than once or twice a year.
I would suggest you stick with a regular DOT3 fluid (Toyota fluid works fine) and do a suck n fill of the reservoir once a year. Just get a dollar store turkey baster, and LABEL it BRAKE FLUID so that it doesn't get used for anything else.
As long as the fluid is clean and light yellow, it will work fine. Murky fluids should be flushed out.
Be aware that a neglected system with dark brown or black brake fluid may need more than a simple flush. You may need to overhaul the calipers to get rid of the corrosion inside. And your brake master can actually fail during the bleeding process (but if it does then it was mostly dead anyways).
Now if you're still set on changing brake fluids, you can use any of the following:
DOT3
DOT4
Super DOT4
DOT4 Racing
DOT5.1
The only fluid you absolutely cannot use is DOT5 which is silicone fluid and is NOT compatible with regular brake fluid.
Hope that answers some of your questions.
Cheers!
__________________
- Brian
86tuning is offline
Old 05-17-2008, 10:35 PM   #5 (permalink)
toyotatom93's Avatar
Man that answered questions I never even knew I had.
__________________
1993 22R-E 4x4 X-cab M/T
toyotatom93 is offline
Old 05-18-2008, 05:20 AM   #6 (permalink)
taikowaza's Avatar
yeah me too thanks 86tuning!!! looks like I'll use Toyota DOT 3. Last question- how many bottles should I pick up from the dealer to do a full fluid replacement?
__________________
Old 05-18-2008, 05:24 PM   #7 (permalink)
I use synthetic fluid, DOT 4, in a gray bottle. I think it is valvoline but I am not sure. If I recall, it is $7 for the large bottle. Anything (except DOT 5) is better than what is in your truck right now if the fluid has not been changed in a while.
PCE91V64x4 is offline
Old 05-18-2008, 05:32 PM   #8 (permalink)
dot 4 doesent hold nearly as much water before you start to run into serious issues. best bet is to go with regular dot 3, and just bleed regularly.
It doesent take that much to flush out the old stuff. i bled my brakes and tried to get most of the old stuff out, and didnt even use a whole bottle.
ps. a vacuum brake bleeder is an awesome investment...
MMA_Alex is offline
Old 05-18-2008, 05:33 PM   #9 (permalink)
Go to a Honda dealership and buy their brake fluid. Unlike all other DOT 3 brake fluids, it's NOT hygroscopic (attracts and absorbs water). Your fluid and rubber brake components will last much longer.
84sr5yoty is offline
Old 07-12-2008, 11:02 PM   #10 (permalink)
Matt16's Avatar
My understanding is that brake fluid absorbes the water that somehow gets into the lines thus preventing corrosion. I don't know how water would get into the lines though..
__________________
1990 Toyota 4Runner 22RE 5spd
Rear Aussie Locker [click here for the review] *Nokian Vativa A/T tires* OME suspension* some other stuff, but I tell people its stock
Matt16 is offline
Old 07-13-2008, 06:50 AM   #11 (permalink)
abecedarian's Avatar
Location: Climbing cell towers- the deadliest job in America
thread resurrection alert!!! lol
glycol based brake fluid is hygroscopic, meaning it absorbs water from the atmosphere so the water gets in through the vent in the master cylinder cap.
__________________
...relax and rest assured: my name is not allan.
Save the world! Protect the environment!! Conserve nature!!!! Eat a vegetarian / vegan.
See, I'm being green.
Quote:
Originally Posted by SwampThing View Post
....But I'm happy to report that I have yet to have a good measure of sense knocked into me. Even when I was testing out my hardhat by runnin full speed into a brick wall, I am still sense-less.
abecedarian is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Looking for a brake fluid level warning switch for 2nd gen 4Runner Fo by Fo Items Wanted 1 01-31-2008 12:47 PM
The Complete Synthetic Fluid Changeover - 3rd Gen 4Runner Bob_98SR5 Maintenance & Repair 0 01-14-2006 05:13 PM
DOT 5 Synthetic Brake Fluid Gentleman 95.5-2004 Tacomas & 96-2002 4Runners 14 01-21-2004 08:23 AM
2nd Gen Fluid Capacities (Already Searched) 92runner Maintenance & Repair Archives 1 10-12-2003 08:58 AM
Advertise on YotaTech.com
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
