Symptoms of bad rear springs? - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 08-28-2007, 11:49 PM   #1
Toyo4x4's Avatar
Symptoms of bad rear springs? Pics added
To go with my other thread:http://www.yotatech.com/f116/rear-sp...ations-123481/
What are the symptoms of rear springs that are going/have gone bad?
Toyo4x4 is offline   Reply With Quote
Old 08-29-2007, 06:48 AM   #2
gixxerjesse's Avatar
well is your truck level?
look at the spring pack is there a broken leaf (like i got).
is your leafs kinked (agian like me).
are your springs flat, or even like a W with reverse arch.
i think i thought of all the big problems someone can corect me if they want
i will guess that a 15 year old truck with a campershell that your leafs are sagging some.
there are many options out there on what to go with depending on what you want to achieve. i am guessing you want to stay stock by reading your post there are some cheap OEM leafs out there.
if you want to save some money and you dont have any major problems that i listed above you could just put some longer shackles on to bring the rear end up
gixxerjesse is offline   Reply With Quote
Old 08-29-2007, 01:32 PM   #3
Most of these trucks have an overload leaf - if they're flat and/or sitting on that overload leaf in the rear, time to get some help.
I just added the add-a-leaf from Jegs.. forget the vendor - about $30 for both sides - levels the 4runner and provides a much better ride. I'm not ready to lift yet, but I think it's one of the best dollar per benefit mods you can do.
dcg9381 is offline   Reply With Quote
Old 08-29-2007, 02:34 PM   #4
Toyo4x4's Avatar
I don't know how flat "flat" is so I'll ad a couple pics.
The first one is probably a little low to tell, but I think the second is looking directly horizontal at it.
Old 08-30-2007, 08:10 AM   #5
you still have some arch but not much, that is about as flat as you would want your springs to go, i dont know if an AAL will give you any arch. dcg could help you with that one but it would probably be helpful and be good for your purpose. wow i forgot how cramped the tire makes it under there
RedRunner_87's aka "Operation Mall Crawler" Build Thread RedRunner_87 95.5-2004 Tacomas & 96-2002 4Runners (Build-Up Section) 60 01-14-2017 05:16 PM
87 4Runner Rough Idle/Misfire issues Sleaker 86-95 Trucks & 4Runners 11 03-26-2016 05:12 AM
Low fuel pressure jbv808 86-95 Trucks & 4Runners 10 10-21-2015 06:03 AM
94' Pickup ZUK Mod - What Springs? Nickdigg 86-95 Trucks & 4Runners 1 07-07-2015 07:04 AM
1984 extra cab build up toyoda8488 84-85 Trucks & 4Runners (Build-Up Section) 2 07-05-2015 11:18 PM
Tags
bad, broken, flat, leaf, leafs, radiator, rear, signs, spring, springs, stabilizer, symptom, symptoms, syptoms, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
