Swapping W56 into V6 4Runner
I'd imagine that you could permitting that the bell housing would match up. I suppose you could swap those so that all the bolts match to the engine. Maybe they're the same?
Also I wonder if you would have to change the pilot bearing too?
That's my 2 cents so don't judge if i'm wrong Lol.
This.
Its been covered 100,000,000 times, but NO you cannot bolt the W56 behind the V6.
Marlin makes an adapter to bolt your gear drive case to the R150F transmission.
What about a W59?
Those were in the Tacomas, right? And those came with the 5vz which is bellhousing compatible with the 3vz, no?
W59 was found behind the 3RZFE 4cyl, not the 5VZFE V6
5VZ's still use an R150F, albeit with a drivers side drop Tcase. You cannot use those either.
Again, there is NOTHING Toyota makes to put your W56 behind ANY V6. If you want to retain the gear driven case(s), but the Marlin adapter.
JookUpVandetti
09-30-2015 08:58 AM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
kelly1450
09-02-2015 12:29 PM
