swapping a v6 automatic tranny for a 5 speed
Old 12-29-2013, 10:31 AM
toyota90's Avatar
Hey everyone I have a 1991 4runner with the 3.slow and auto tranny I am kinda a newbie to Toyota so was wondering how hard it would be to swap the auto for 5 speed
Old 12-29-2013, 12:33 PM
wyoming9's Avatar
Red face
It depends on your idea of hard.
For some on here almost impossible others could do it with their eyes closed
If you can change a clutch or pull an Auto trans you will be fine.
One should have help for the heavy lifting just in case but it can be done alone if really needed
One big Hint makes it so much easier.
Have the parts vehicle right there or a weekend will turn into several running for things you never thought of.
Old 12-29-2013, 02:14 PM
toyota90's Avatar
alright thank you i have just been conteplating it over the last week because the auto tranny just isnt cutting it. Is there a length difference between the 2 trannies and is there any cutting through the firewall to install?
Old 12-29-2013, 02:34 PM
Punchy's Avatar
The driveshafts are a different length
You have to do mild cutting of the trans tunnel
You need the peddle bracket along with the clutch peddle
You can buy new master and slave cylinder
You have to run a hardline from master to soft line to hardline again to the slave.
There is a little cut and splice to the wiring harness to to fix the park-neutral start issue and to fix the ECT error.
There are several conversion threads on here.
Old 12-29-2013, 04:51 PM
toyota90's Avatar
Thanks for all the help guys this will get me working on it in no time.
Old 12-29-2013, 10:40 PM
wyoming9's Avatar
Red face
I would read all the threads on here it will give you an idea of all the possible problems.
I think in just about all of them someone always forgets something.
That`s why I love having the whole parts truck what you don`t want can be parted or just scrapped when finished.
I got the whole Truck to do this swap for $300.00
LittleUgly
15
01-02-2020 01:30 PM
urabus
11-10-2015 07:38 PM
Thamuel_
Domestic Swaps
10-03-2015 11:15 AM
bradahman
10-01-2015 09:24 AM
Hugh_Mann
09-16-2015 03:59 AM
Quick Reply: swapping a v6 automatic tranny for a 5 speed
