Swapping Transmission
Old 07-21-2010, 12:01 PM
BigSwole's Avatar
  • Could i swap a 2wd Transmission into my 4x4 pickup if i swap the tailshafts?
I was told it should work but i am clueless at best...
90 Toyota pickup 4x4 22-re (needs replacing)
93 Toyota Pickup 2WD 22-re (good)
Will it work and if so what all needs to be done!
Thanks in advance
Old 07-21-2010, 12:07 PM
akaphilly's Avatar
it wouldnt work.
Old 07-21-2010, 12:11 PM
BigSwole's Avatar
I figured as much but figured id ask anyways..
Thanks for the help
Old 07-21-2010, 05:48 PM
b4wheeler's Avatar
It will most likely work just fine.. You just won't be able to reinstall your transfercase and therefore you will be left with two wheel drive..........
Liadrin
04-25-2022 02:54 PM
mskalmus
05-28-2017 07:51 AM
jjrbus
07-17-2015 07:06 AM
Poncho0206
07-10-2015 06:21 PM
madxman21
07-09-2015 10:26 AM
Quick Reply: Swapping Transmission
