Swapping in Tilt Steering into a 94 truck
Greetings My 16yo son recently bought a 94 Pickup. Super nice truck but he is pushing 6'3" and the steering wheel is very tight to his legs.
Has anyone swapped in a tilt steering column from another truck or 4 runner?
If so what year, parts, cost etc...
I have checked with a few Toyota junkyards and they were not much help. Bodyshops zero info.
I want see if this is even possible.
You should be able to swap a tilt column from any 89-94 pickup. Just remember to get the keys for the ignition with it, or you'll probably need a locksmith to swap out the cylinders. I'm 6'1", and have tilt. But the extra cab is what helped me with the leg room. Those standard cabs are a little tight.
I've been thnking about swapping in a tilting steering wheel too. From a 93 4runner into my 91. Can anyone say a little more about the ignition cylinder? Would I have to use a different key, are there any options for switching all of it?
GreenLion
06-07-2021 10:49 AM
voiddweller
19
05-02-2016 09:10 PM
