Swapping entire driveline + 7mgte, anyone? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-12-2008, 09:08 AM   #1 (permalink)
4Run_95's Avatar
Send a message via MSN to 4Run_95 Send a message via Yahoo to 4Run_95
Ok, im doing some research on what is possible and not when it comes to swapping things in my 4Runner. I want to be preperad when the 3,0 explodes.
My dream would be a 7mgte, however the rules here in Sweden are just so silly. If I want to get it legel I will have to change the entire driveline! Great.
So I was just going to check with you guys, what would you recommend as a entire driveline-package? (including front and rear axle, tranny and transfer). I want to use the 7mgte and a 5 speed manuell box.
Thanks for any tips!!
__________________
1995 Toyota 4Runner V6 3,0 5 speed
2002 Subaru Outback H6 3,0 auto
4Run_95 is offline
Old 11-13-2008, 12:17 AM   #2 (permalink)
4Run_95's Avatar
Yes, by the way, that means that i cant use the R150...
__________________
4Run_95 is offline
Old 11-13-2008, 09:44 AM   #3 (permalink)
annoyingrob's Avatar
You can swap the tail-shaft from your R150 on to the 7M-GTE 5-speed (R154) so that it mates to the stock transfer case.
annoyingrob is offline
Old 11-13-2008, 10:24 AM   #4 (permalink)
toyminator2000's Avatar
Here is a whole website dedicated to swapping the Supra inline 6 cyl into a toyota truck.
http://www.supracharged.com/
__________________
YOU ONLY NEED TWO TOOLS IN LIFE - WD-40 AND DUCT TAPE. IF IT DOESN'T MOVE AND SHOULD, USE THE WD-40. IF IT SHOULDN'T MOVE AND DOES, USE THE DUCT TAPE
toyminator2000 is offline
Old 11-13-2008, 11:54 AM   #5 (permalink)
Personally I would not want a 7M in my truck.
You want your truck to be reliable, right? Don't put a 7M in it.
I hang out with a bunch of people with MK3 Supras, I've had one myself. Even the ones with lots of money in them are breaking all the time. If you do go 7M, be sure to keep about a dozen headgaskets with you.
A couple of my friends have gone 1JZ, the others wish they could.
__________________
Better to remain silent and be thought a fool than to speak out and remove all doubt. - Abe Lincoln.
chrisbnaz is offline
Old 11-13-2008, 12:27 PM   #6 (permalink)
Swansen's Avatar
Send a message via AIM to Swansen Send a message via Yahoo to Swansen
x2 on that. Alternatively, you could just go for simplicity and swap in a 22re. On that, i'm sure you could find a good number of diesel around, a 2L-T mechanical diesel swap is a direct fit and no to much messing around. Alternatively the 1kzte's are also SWEET engines. With ether of those options you might not have to swap out the entire driveline.
__________________
88 PU, 22RE, custom bed, other random things, in the process of being restored, more or less, and driven daily..... My PU
Swansen is offline
Old 11-13-2008, 11:41 PM   #7 (permalink)
4Run_95's Avatar
ok, thanks for your replies!
The thing is, I HAVE to swap the entire driveline (both axles, gearbox and tranfercase) to be able to get the truck legal with another engine then the 3vze...that sucks, but its the truth.
So I was thinking if there are any driveline swaps that are more resonable then others...
Thanks for the diesel tip, I will take that in mind.
Also, dosnt hks make metall hg,s for the 7m? Ive heard that you can actually make that engine bulletproof with a metall hg and arb studs?
Thanks again for all your help, and to this great forum
__________________
4Run_95 is offline
Old 11-14-2008, 12:11 AM   #8 (permalink)
breknraj's Avatar
I have no idea if anything was sold with the 3.4 5VZ-FE form the Tacoma and 4Runner in your area, but the swap would entail far less fabrication on your part. You also might be able to skirt the rest of the driveline by showing the authorities that the 3.4 driveline uses the same components.
Take a look in the 3.4 section of motor swaps - that might give you a better idea abut whether it's feasible, or not.
__________________
Raj : 1960 Homo Sapien. 192cm, Blonde, Blue. Soon to lose spare tire.
Worf : 1990 SR5 Xtracab 4x4 5 speed, Inca Red Metallic. 3.4 converted, with Taco 5 spoke alloys, 275/65R16 BFG AT K/Os. Soon to add rear e-locker.
breknraj is offline
Old 11-14-2008, 05:44 AM   #9 (permalink)
Swansen's Avatar
Well, my point with the diesel and the 22re is that they put those engines in your generation 4runner, so would you still have to do a drivetrain swap at that point ??
__________________
Swansen is offline
Old 11-16-2008, 03:25 PM   #10 (permalink)
You're going to be hard pressed fitting a 7M Drivetrain into a pickup. The 7M-GTE only came in a MA70 Supra, which was only available with IRS. There was a guy in BC that was working on installing the Supra's IRS into a pickup, but I never followed it, so I don't know if he ever finished.
Oh, and yes HKS, as well as Cometic, and a few other companies make metal head gaskets for the 7M. Yes, it solves the head gasket issue, but make sure you get the head and block properly machined first, and install a good set of head studs.
Old 11-16-2008, 09:59 PM   #11 (permalink)
4Run_95's Avatar
Thanks again for the help
I will check this up, with the 3,4 and driveline. The Landcruiser 90 with the 3,4 was sold here.
__________________
4Run_95 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
87 4runner w/7mgte mland2 The Classifieds GraveYard 6 11-07-2007 06:52 PM
7mgte swap 7mPower 84-85 Trucks & 4Runners 5 08-27-2007 09:07 PM
Help ?s for 7mgte swap mfxsupervillain 86-95 Trucks & 4Runners 2 11-21-2006 06:19 PM
7mgte vs 3.4? BeevDawg 95.5-2004 Tacomas & 96-2002 4Runners 7 11-09-2004 10:40 PM
7MGTE install NCSU-4runner North Carolina 22 01-16-2004 01:48 PM
2009 InternetBrands, Inc.
