swap from mechanical to electronic speedo?
Old 01-16-2010, 05:35 PM
rotccapt's Avatar
hi all is it possible/ cost effective to swap from a mechanical cable driven speedo to an electronic speedo. i have an 86 toyota pick up
Old 01-16-2010, 07:12 PM
laskt9's Avatar
im interested in the answer too
Old 01-17-2010, 09:24 AM
tacho75's Avatar
me 2 ..........
Old 01-17-2010, 09:57 AM
hiltu's Avatar
some GPS units now display speed. I may go that route if/when i get gears
Old 01-17-2010, 10:27 AM
Staff
DeathCougar's Avatar
They did not start electrical speedos until 1992 so unless you want to rewire your entire truck, PLUS deal with the headache of parts that are MORE expensive, i wouldn't do it.
That $70 cable is much cheaper than the $240 speed sensor.
Old 01-17-2010, 11:38 AM
airkewld4life's Avatar
It can be done without re-wiring you entire vehicle
Google Hall effect speedometer sender. There are multiple options but I chose to buy the Autometer one. I did this exact thing to one of my Bugs. I wanted all Autometer Cobalt series gauges and unfortunately, they did not make a mechanical Cobalt speedo. So, I started doing some research and came across the Hall effect senders. Most of the senders say they are for Ford or Chrysler/GM but the cable from my Bug threaded right on. Here is a basic install sheet from Autometer
http://www.autometer.com/productPDF/1168.pdf
Good luck
Old 01-17-2010, 11:53 AM
Staff
Autometer being aftermarket gauges.
I should have clarified, i was talking OEM parts only.
Old 01-17-2010, 11:59 AM
Wink
Touche.
OP should clarify as well
Old 01-17-2010, 04:44 PM
rotccapt's Avatar
oem after market does not really mater. i finaly got my mecanical settup working again but i am still looking at ideas. i found a unit on merlin crawler that supposedly will work too.
jasonty
41
12-23-2018 01:00 PM
mskalmus
05-28-2017 07:51 AM
keithporter83
07-24-2015 07:37 AM
msane99
07-11-2015 08:08 PM
Tyler Cunningham
07-11-2015 10:18 AM
Quick Reply: swap from mechanical to electronic speedo?
