Swap a 22RTE for a 22RE - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-18-2007, 10:31 AM   #1 (permalink)
Can this be done using the same Trans?
Truck 1986 4Runner with 22RTE...it's a dog!!!! The Body and interior was way too good to let this truck get away from me. I will be SAS'ing as well.
Teamsobaco is offline
Old 08-18-2007, 10:44 AM   #2 (permalink)
Why not just fix the 22RTE and have something that will kick the 22RE?
netgodsrdn2 is offline
Old 08-18-2007, 11:12 AM   #3 (permalink)
91muddog's Avatar
or find a fresh 22re and put the turbo sysetm on it?
__________________
1995 Toyota Avalon: 3.4 Auto with ect power button
Quote:
Originally Posted by stormin94 View Post
And changing your blinker fluid regularly reduces build up, and allows for higher visibility. But only use the Toyota brand from the Toyota dealership.
Quote:
Originally Posted by SwampThing View Post
Holy front shackles batman!
[/size]
91muddog is offline
Old 08-18-2007, 11:32 AM   #4 (permalink)
drew303's Avatar
stock turbos were crappy on that motor.. They werent built that well
I'd personally just fix that 22RTE ...
__________________
1987 Pickup, single cab, 22R, new head, 260 cam
TG 3" SAS, rear disc brakes, chromoly rear axles, Chromoly Birfs, Tcase brake, 37x12.50R15 MT/Rs, 5.29 gears, rear Aussie Locker, front Detroit Truetrac.
drew303 is offline
Old 08-18-2007, 01:34 PM   #5 (permalink)
If it's a dog, it's because the turbo is dead, so you're running a choked, low-compression N/A motor. Search here and on pirate4x4 for swapping just the turbo for a more modern one. Many people have done it and it's a great motor with a better compressor.
ohio is offline
Old 08-18-2007, 04:22 PM   #6 (permalink)
Yeah I know for sure it needs a compressor, it spools up but takes a long ass time...
Old 08-18-2007, 06:04 PM   #7 (permalink)
Send a message via AIM to dcg9381
Spool shouldn't be an issue at all with that turbo. If it won't spool, something is seriously wrong with it.
There is a TEC kit to replace it - or drop in a Garrett.
A 22RE will drop in with existing driveline, but you have to replace the ECU and do some additional rewire.
If it's in good shape minus the turbo, I'd fix it.. A turbo truck in good shape is usually worth a decent chunk of change.
__________________
http://www.22REturbo.net
dcg9381 is offline
Old 08-19-2007, 01:48 AM   #8 (permalink)
Quote:
everyone says that....but I've yet to find someone who's tried it.
seems to me, if you use all RTE sensors, the RTE ECU and MAF should be able to tell that there's less air going in than with a turbo, and therefore put less fuel into the motor.
I intend to get myself a wideband AFR gauge, and try it.
__________________
-Chux
'87 Turbo Toyota 4Runner, Stock suspension, 31s
"I can't be lost, I have 4-Wheel Drive!"
Subaru -- All We'll Drive
Member: NSW, USC, MNS, C4C.
Numbchux is offline
Old 08-19-2007, 08:41 AM   #9 (permalink)
Quote:
Originally Posted by Numbchux View Post
everyone says that....but I've yet to find someone who's tried it..
Thats because most turbo owners know they've got a leg up on the stock 22RE setups. I do know of several people who have gone from 22RE to 22RTE using the 22RTE ECU. Honestly, all they lose is 02 heat. They have to swap injectors and have similar year trucks.
Have a look at the pin out of the 22rte vs 22re - they're remarkably the same in terms of pin out. Only minor differences.
__________________
dcg9381 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
22RTE to 22RE....how hard? Numbchux 86-95 Trucks & 4Runners 11 05-19-2007 10:26 PM
22RTE/22RE hybrid running. dcg9381 86-95 Trucks & 4Runners 34 12-19-2006 07:02 PM
dif. between 22re and 22rte Matt80539 86-95 Trucks & 4Runners 4 06-04-2006 07:37 PM
Replace with 22re or 22rte?? blkntan 95.5-2004 Tacomas & 96-2002 4Runners 5 11-28-2004 12:14 AM
85 with 22RE, or 86 with 22RTE? CGuava 95.5-2004 Tacomas & 96-2002 4Runners 3 03-12-2003 02:27 PM
2009 InternetBrands, Inc.
