Suspension Travel/wheel rubbing
Old 04-24-2010, 04:48 PM
pisc2bn's Avatar
So, I am a new 4runner owner/trail runner and the other day I was out on a trail and I was having issues with my wheels rubbing the inside of the wheel well as I was going over some minor stuff....like there was not enough resistance from the springs to keep the wheel out of the well. I am not sure what the issue is. I talked to some friends and they said there were some type of straps to minimize the travel of the wheel. Like I said I am a newbie to the off road world so I am not that informed about it but I want to be able to use my 4runner to its max. I have a 4" body lift and I was thinking about doing a suspension lift but I dont know if that will remedy my problem or not. What do y'all think?
Thanks!
Old 04-24-2010, 05:39 PM
rattlewagon's Avatar
Whats the specs on the runner? what are you running for tires? 4 inch body lift? are you sure? thats really tall for a body lift.
There are easy ways to get a little more height out of your truck such as Ball joint spacers and LC coils. The SEARCH button is your friend.
Old 04-24-2010, 05:56 PM
yotaman85's Avatar
your tires are too big. that is your only problem. the fact that your suspension lets your tires stuff all the way into your fender is a good thing. you can cut your fenders to make it clear or you can get aftermarket fender flairs.
Old 04-25-2010, 08:30 AM
pisc2bn's Avatar
33X12.50, and yes a 4" 4crawler body lift.
Old 04-25-2010, 11:16 AM
Armalite's Avatar
Is it rubbing when you are going straight? or is it rubbing when you are turning at full lock? i would think a 4'' body lift would clear 33s easy. I know that the wider tires tend to rub the pinch weld when turning hard.
hope that helps
Old 04-25-2010, 12:54 PM
pisc2bn's Avatar
It doesnt rub when I am going straight. Just when I was climbing over some rocks. Hardly rubs when I turn...just when I am negotiating obstacles.
live4soccer7
05-11-2016 06:52 PM
Thamuel_
Domestic Swaps
10-03-2015 11:15 AM
ktm192k
10-01-2015 08:47 AM
JookUpVandetti
09-30-2015 08:58 AM
myotherrideisayoshi
09-29-2015 05:41 AM
Quick Reply: Suspension Travel/wheel rubbing
