Surging Idle 1990 22re pu: need suggestions
I am about to give up on me friends 1990 22re pu. We have tried almost everything mentiond on yotatech to fix the surging idle. It seems to be getting worse and we are about to light a fire
It would help if you told us what you have already done ?. What i would recommend is that you check the TPS for proper adjustment, check the idle, if its set to high it will cause surging, also check for vacuum leaks.
What about unplugging the mass air flow sensor while running and see if it changes.Mine went bad on a 22RE and it started running rough and very rich.If not that maybe another computer.If all sensors are good maybe it is the brain thats talking to the sensors!
HEY GUYS, I FINALLY REGISTERED AS A MEMBER. BLUEYODA HAS BEEN DOING MY POSTS SO FAR. I HAVE TRIED EVERYTHING THAT EVERYONE HAS MENTIONED, EXCEPT CHANGING THE COMPUTER. ALL HELP HAS BEEN GREATLY APPRECIATED, BUT TO NO AVAIL. THE ONLY TIME THE SURGING GOES AWAY IS ON A WARM DAY LEADING ME TO BELIEVE THAT PERHAPS THE VALVES MIGHT NEED TO BE DONE AS THEY COULD BE AFFECTING PRESSURE IN THE HEAD GOING TO THE TB. REALLY AT THIS POINT I'M GRASPING AT STRAWS.
I HAVE TWO SPARE PARTS VEHICLES SO ANYTHING AND EVERYTHING CAN BE CHANGED
IF ANYONE HAS ANYTHING ELSE THAT MAY BE HELPFUL PLEASE POST UP. THANKS AGAIN!
Changed/tested
TPS
Enitre TB
egr
thermostate
vacuum lines
fuel filter
air filter
PVC
lines going to iavc
MAF
Changed/tested
TPS
Enitre TB
egr
thermostate
vacuum lines
fuel filter
air filter
PVC
lines going to iavc
MAF
MMA_Alex
25
04-18-2017 05:07 AM
