surf body lift..
Old 08-29-2014, 04:36 AM
toys2's Avatar
surf body lift..
g'day out there.
jz whacked a set of cepek mud country's under my surf.
LT305/70R16 they are.
took them of my hilux ute(pick up) on wich I spent considerable money on suspension lift to accommodate them.
the surf already is lifted tho not the body.
I'll need to go 2inches higher on the body and am askin about the change in the height of centre of gravity.
clearly there will be some change... tho is the change going to be significant?
I should mention, the rims are offset and increase my standard wheelbase width by 2inches each side.
thanks.
Old 08-29-2014, 10:06 AM
Staff
Terrys87's Avatar
I had a 2 inch body lift on mine and not noticeable issues. Just incase some dont know what the Surf is, it is a 4Runner in different parts of the world. You lucky enough to have the diesel?
Old 08-29-2014, 10:49 AM
Robert m's Avatar
If you still have the sway bars on it, you probably wont notice much of a difference.
Old 08-29-2014, 11:11 AM
mudharvest23's Avatar
I have a 3in BL with 33X12.5s on mine and I can still take backroads at freeway speeds with no fear of rolling! Body lifts affect your COG the least out of all lifts, mine drives like its stock. You probably won't even really notice it.
Old 08-31-2014, 05:34 AM
toys2's Avatar
surf body lift..
ok. no worries.
as far as the riser blocks go, nolathane or solid alloy, is there any differences between the two?
Old 08-31-2014, 05:38 AM
toys2's Avatar
surf body lift..
she's 22r mate.
my ute was 2.8 diesel..tired as...
before I put a supercharged v6 from a VX Holden Calais...
shes awake now!!
Badlander
06-20-2016 07:20 AM
smithyboy69
11-28-2015 04:13 PM
Badfish740
09-04-2015 04:21 AM
AkitaDog
09-03-2015 09:01 PM
Yowski
08-24-2015 12:17 AM
Quick Reply: surf body lift..
