Supra AFM in 22re - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-19-2008, 11:23 AM   #1 (permalink)
Blackulua's Avatar
Supra AFM in 22re
I used a Supra AFM #22250-35020
#197100-2470
I won it on ebay and looked similar to the 82 Supra AFM.On both ends of the AFM is 3 inches big.The inside of the AFM had different electronics that would not work with the 22re computor.So I took apart my 22re AFM plug-in,circuit board, and needle.Everything fits perfect and I soldered it together and made a 3" pipe with a 3" hose connected to the AFM and a 45 degree coupler to the LC big throttle bore (later type).
The truck has 33's with 4:88 gears and was running just fine even but it lags on the throttle even with DT tri-Y headers and Flowmaster super 40 muffler and large 2.5 pipes with the stock AFM.With the Supra AFM & later type plenum & LC big throttle bore ,the truck on the shift it seems to have a smoother airflow & response on the throttle and much better pickup even while running lower speeds on higher gear.The lag on 4th gear up the hill is unnoticeable.I will later post the pics today.The rest of the block,head & cam is stock.
__________________
Black 1988 4wd Pickup 22re / White 1988 4wd 22re /1990 2wd PU 22re
Blackulua is offline
Old 01-19-2008, 03:47 PM   #2 (permalink)
Blackulua's Avatar
Heres the pics
__________________
Old 01-19-2008, 08:43 PM   #3 (permalink)
just a 22re's Avatar
Send a message via AIM to just a 22re Send a message via Yahoo to just a 22re
ok buddy you have some explaining to do here what did you do to get rid of the 4th gear hill climb go away? you took a soup air flow and took the stock 22re air flow insides and put them in the soups case?? so that the stock 22re is now a 3in flow throw insead of the 2in?
__________________
GO TEAM LAZY!!
my name is ALLAN
yeah its a 22re 5-speed 4wd 1987 4runner with a cam, snorkel, welded rear
Quote:
Originally Posted by SwampThing View Post
Going wheeling and going swampthinging are two totally different things. Wheeling is doing something with the expectation of having fun in the process. Swampthinging is doing something and knowing you'll probably end up in a hospital in the process.
http://www.yotatech.com/misc.php?do=flashchat
www.myspace.com/whatsadisplayname
just a 22re is offline
Old 01-19-2008, 09:14 PM   #4 (permalink)
ozziesironmanoffroad's Avatar
Send a message via AIM to ozziesironmanoffroad
i believe a write up is in order......
__________________
The 22r series engines are made from the fires of hell, and will fight tooth and nail to not be sent back.
1988 Toyota P/U 4x4
22re, 1200 miles on the rebuild
engine builder .268 cam
pioneer CD deck
31x10.50x15 BFG A/T
BAJA 100W lights on prerunner bumper
KC Daylighters 100W
rancho rs5000
MUD IS A VALID PAINT JOB!
If not living life to the fullest, why live it?
my trucks official buildup thread
ozziesironmanoffroad is offline
Old 01-19-2008, 09:16 PM   #5 (permalink)
Blackulua's Avatar
Quote:
Everyones 22re is different from others because of different set-up.My engine is high mileage stock till I overhaul and replace my clutch with a 6 puck clutch from Trail Gear.Today I ran my truck more on the flat and hills on 4th gear.The engine responds much better on the throttle comparing to the stock AFM & stock later type TB that I had on before.The top end is not what Im looking for its the bottom end is more responsive even while shifting quickly up to 4th gear on the flats and climbs hill much better.
I have another truck that has more engine mods but not expensive like a complete LCE motor.I also have a 82 Supra AFM with early type LCE TB on it.This truck runs really well on the low and top end and it accelerates fast because Im running 30 x 9.5 tires & 4:56 gears.Even with 31 x 12.5 the truck easily spins the rubber like a car.
The truck still gets 18mpg worst and 22 mpg best.
__________________
Old 01-19-2008, 09:26 PM   #6 (permalink)
so how did you do this cause im guessing im not the only one that wants to do this mod and you just opened a big thing with the 22res here we all want the 4th gear hill climb to go away so do i smell a right up here?????
__________________
GO TEAM LAZY!!
my name is ALLAN
Old 01-19-2008, 10:13 PM   #7 (permalink)
Send a message via AIM to shaeff
yeah, people have been doing this for a while. you can probably find info on it by searching the 'net. though, i don't think you have to switch the electronics if you get an AFM from a 5mge.
__________________
My heatercore replacement writeup with pics.
-'94 Toyota 4X4, 22re, 31X10.5 BFG M/T's, 5 speed, MC rear bumper. (Winter DD/ off road fun)
-'95 BMW M3, modded/suspension, sticky rubber, back road monster (Summer DD)
-86.5 Toyota Supra, too much to list. (Never-ending project)
shaeff is offline
Old 01-19-2008, 10:17 PM   #8 (permalink)
so get one from a 5mge and it should work right? cause i really wanna do this here i like having power thanks
__________________
GO TEAM LAZY!!
my name is ALLAN
Old 01-20-2008, 04:19 PM   #9 (permalink)
Blackulua's Avatar
I cant find the ebay AFM that I won but on both ends its 3" around.I won another supra AFM but it was the wrong one to use with the 22re.The person that was selling these had a lot but now I dont see any.You just got to keep looking around.
__________________
Old 01-20-2008, 07:16 PM   #10 (permalink)
JamesD's Avatar
All he did was use the supra housing and the guts out of the 22re and resoldered the wires. Thats it. Since the Supra has totally different electronics you would have to use the 22re guts unless you want to fabricate the harness. I believe the Supra VAFM has the intake air temperature sensor built in it and the 22re has it in the intake.
James
__________________
New Tacome V6 transfer case http://www.yotatech.com/f107/sale-br.../#post50755569
Various Toyota truck/4Runner switches for sale http://www.yotatech.com/f109/various...trucks-148139/
JamesD is offline
Old 01-20-2008, 11:07 PM   #11 (permalink)
ahhhh thanks man that makes alot of sense there
__________________
GO TEAM LAZY!!
my name is ALLAN
Old 01-21-2008, 05:53 PM   #12 (permalink)
the 5mge AFM is bolt- on. the 7m isn't
__________________
shaeff is offline
Old 01-22-2008, 08:52 AM   #13 (permalink)
InternetRoadkill's Avatar
I'd love to convert the VAFM to a more modern MAF. It wouldn't be that hard to do, but I don't think there is enough demand to make a kit to cover the cost of the dyno time needed to calibrate a conversion.
InternetRoadkill is offline
Old 01-22-2008, 09:00 AM   #14 (permalink)
CJM
CJM's Avatar
Ok, so what ya need to do is find the correct AFM, then take the guts out of a 22re and put it in there and hook it all back up?
__________________
96' T100 SR5 4x4, ISR mod, Custom ABS snorkel, KC 57's Hella optilux el cheapo backup lights. Cobra 19III CB, Firestick 4ft antenna, Bilstein shocks.
Be polite. Be professional. But, have a plan to kill everyone you meet.
CJM is offline
Old 01-22-2008, 09:31 AM   #15 (permalink)
Send a message via AIM to dcg9381
Quote:
Assuming you could do it - and the stock AFM uses a very non-standard signal structure, which is why most piggy backs don't work with the 22re/22rte:
Why do you need a dyno to tune it? You could do 95% of the tuning on the road via a wideband.
__________________
http://www.22REturbo.net
dcg9381 is offline
Old 01-22-2008, 11:19 AM   #16 (permalink)
yeah i tried a safc in my truck no luck ran like crapy crap but it looked good telling me the rpm's and tradle angle
__________________
GO TEAM LAZY!!
my name is ALLAN
Old 01-22-2008, 12:10 PM   #17 (permalink)
The weird signals from the VAFM could be duplicated without too much fuss. (Ah the world of micro controllers.) I did consider just sticking a MAF inline with the VAFM to get a starting point set of signals to work with and I guess you could refine it over time with a wide band O2 sensor. Of course. ECU is going to do that for ya as well over time. Hmmm. The dyno would be nice because you could see if you're really getting any bang for buck.
Old 01-22-2008, 02:32 PM   #18 (permalink)
I agree that a broad range of signals could be duplicated. It'd take a decent amount of testing, probably a programmable IC, and a good understanding of electronics.
I wouldn't stick *anything* in-line with the VAFM, unless it had an extremely high impedance - otherwise you're going to impact the values read from the VAFM.
I would, however, probe the VAFM with a oscilliscope and various RPMs. It'd be best to do it under load, which is going to be hard.
I'm not convinced that the 85-88.5 ECU has any sort of "learning" capacity. Learning capacity may be true of more recent ECUs, but I've seen no evidence or documentation on 85-88.5 that says it can learn mixture. It does adjust, within limits, when running in closed loop.
The narrowband 02 will never be as good as a wideband. It knows 3 things: rich, lean, and stoich. It doesn't really know how rich or how lean.
Would I mod the AFM? Sure.. I'd do it in combination with modding the TB also and a late model plenum... If you compute the area of the stock AFM flapper door and the 55mm TB, you'll notice that they are very close. I'm also appreciative of this "how-to" as I see people ask about it a lot.
Will this make a difference on a stock truck? Dunno... Let us know!
__________________
dcg9381 is offline
Old 01-22-2008, 03:30 PM   #19 (permalink)
What I meant by inline was not to place the MAF inline with the electrical signals. Rather, I would put the MAF between the VAFM and the throttle body. A data acquisition system would be needed to record the signals from the VAFM and the MAF so that you could build a signal conversion table.
This isn't hard to do, but as I mentioned, it's questionable as to whether it's worth the effort and cost.
Old 04-24-2008, 03:17 PM   #20 (permalink)
84 yota ex-cab's Avatar
So what year of the supra AFM would work on a 1989 22re?
__________________
89 toyota 4x4 ex-cab 22re 5 speed header flowmaster 31's
84 yota ex-cab is offline
Old 08-04-2008, 04:40 PM   #21 (permalink)
What about fuel delivery..diggging up an old thread
I did a conversion very similar to this in my 87 325is BMW. I took a VAFM from a 3.0l 535is and put it in my 2.5l 325. granted I had to swap the internal electronics from the 325 VAFM to the 535 VAFM. After the swap I was running lean. I had to upgrade to larger FI's and raise my FP .
I know this is not a 6cyl BMW , but By doing this on the 22re would there be any fuel issues?
Could the injectors be near their limits as far a duty cycle to make up for the extra air? Would there be any need to adjust fuel pressure? Or is it really plug and play as it seems.
thanks
Geoff
BigRedTruck is offline
Old 08-04-2008, 06:42 PM   #22 (permalink)
myyota's Avatar
You can open up the AFM and adjust it to run a little richer.
myyota is offline
Old 08-04-2008, 06:55 PM   #23 (permalink)
abecedarian's Avatar
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
Quote:
Originally Posted by BigRedTruck View Post
>snip<
thanks
Geoff
the stock injectors are capable of flowing enough fuel for nearly any subtle mod you can throw at a 22re, up to about 4-6 psi of boost from a turbo or supercharger.
__________________
Quote:
Originally Posted by DeathCougar View Post
Abe so far has been spot on, 100% correct. As usual
Insomnia: it's a way of life.
abecedarian is offline
Old 08-04-2008, 07:12 PM   #24 (permalink)
The missing parts I need to convert the stock VAFM to a 3" GM MAF will be arriving tomorrow. The translator is programmed and just needs the remaining pieces installed. I should be able to try it out on wednesday.
Old 08-05-2008, 01:51 PM   #25 (permalink)
Thanks for the replies, that answers my questions, now I just need to find one..
Tags
22re, 4runner, 82, 85, 89, afm, engine, hillclimb, insad, o2, pickup, supra, toyota, translation, turbo, wideband
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
22RE AFM and ECU drew303 The Classifieds GraveYard 2 04-04-2007 01:37 PM
WTB working 22RE AFM SuperBlue The Classifieds GraveYard 2 02-19-2007 08:40 AM
WTB 89 toyota pickup 22re AFM YOTAKIMMER The Classifieds GraveYard 2 11-13-2006 05:23 PM
22re Supra AFM Swap questions Adh007 95.5-2004 Tacomas & 96-2002 4Runners 1 03-22-2005 10:09 AM
Supra AFM in a what?!?! Wildcat_4R 95.5-2004 Tacomas & 96-2002 4Runners 4 03-05-2005 11:57 AM
2009 InternetBrands, Inc.
