Super sensitive gauge?
Old 01-30-2008, 08:04 AM
yotaman90's Avatar
Question Super sensitive gauge?
I just noticed the other night that when I have the turn signals on, the voltmeter moves with the flashes! I got home and then turned the signals on again and did it again. I then turned off the headlights and the gauge went up a bit, then I cliked the signal arm forward for the brights and then turned on the headlights again, and the gauge went down even more then before. The gauge barely twitches though, it's not that significant, but its noticeable. I'm not sure if this indicates something or not, but I sure would appreciate the help. I have a video of it but I don't know how to post it.....
Old 01-30-2008, 08:22 AM
WCorbett's Avatar
This is normal. It does that with almost any lights. All of our vehicles do it as well.
Old 01-30-2008, 08:42 AM
nonamer's Avatar
Yup, mine does the exact same thing... worried me too the first time I noticed it.
Old 01-30-2008, 03:03 PM
fire5's Avatar
Me three. Until this thread I've always wondered.
Old 01-30-2008, 10:34 PM
notanymore's Avatar
yeah i would say its pretty normal.
Old 01-31-2008, 04:02 AM
mt_goat's Avatar
Me four, mine even does it with a high output alternator.
Old 01-31-2008, 04:29 AM
ozziesironmanoffroad's Avatar
mine does that too. but i dont have a volt gauge YET. what happens is if my check engine light is on(egr), when i use a turn signal, the light flashes to the turn signal. im sure its somewhat normal
Old 01-31-2008, 09:07 AM
yotaman90's Avatar
Thanks I feel better about it now, it had me worried! The only thing is though, look at the difference when the rear defroster is off versus when its on. 1st pic defroster off, 2nd pic defroster on
Attached Thumbnails Super sensitive gauge?-voltmeter-1.jpg   Super sensitive gauge?-voltmeter-2.jpg
Old 01-31-2008, 09:22 AM
MRecio's Avatar
There was a writeup on someone that replaced the the power wire to the fuse box and maybe some other stuff and got completly rid of this on his 4runner ive been trying to find it but cant remember the posters name or the topic he used. Maybe someone with better searching skills will come along and make me look dumb and post a link to it.
Old 01-31-2008, 10:14 AM
80W90's Avatar
mine does the exact same thing. totally normal. but what is strange is, it also plays the first thirteen notes of the dixie song too. hmmm
Old 01-31-2008, 10:52 AM
yotasavg's Avatar
ever seen it move when a sub hits?
Old 01-31-2008, 11:09 AM
Belize Off Road Team's Avatar
anything that uses over a certain amount of power makes the gauge move, with my 100/80W hella H4 bulbs on stock wires, it uses the same power on the gauge as yotaman90's defroster does. and when i signal, it's the same, it moves only slightly. the only way i know to reduce it, is switch as many lights to LEDs as you can.
Old 01-31-2008, 12:51 PM
MRecio's Avatar
Ok I finally found the write up. He was having the same gauge problem you guys described and was able to fix it.
https://www.yotatech.com/forums/f116...rite-up-33526/
some good stuff in there.
ashamsuddin
17
01-13-2023 03:17 AM
punks_is_4x4
02-26-2016 04:29 PM
Jdgarrison
10-01-2015 05:22 PM
JookUpVandetti
09-30-2015 08:58 AM
93RedKrawler
09-29-2015 02:50 PM
Quick Reply: Super sensitive gauge?
