sunroof drain tube exits...WHERE???
Old 05-14-2008, 07:37 AM
mark21's Avatar
Unhappy sunroof drain tube exits...WHERE???
I've got a 1990 SR5 pickup that I bought new with a sunroof already installed. Never had a problem with it until a few days ago. During a heavy rain, water started coming INTO the cab after FILLING UP the rocker with water. I pulled out the passenger seat and the soaking wet carpet to access the passenger side kick panel. Lots of rust, so I vaccumed out the opening and lifted the end of the drain tube out. I looked into the access hole but didn't see much of anything as far as a plugged up exit hole. I poked around in the hole with a box end wrench but didn't feel as if there was an exit hole down there. After almost twenty years of ownership, I 've got a hard time believing that something isn't clogged . Anybody out there have any ideas? Much appreciated.
Old 05-14-2008, 04:13 PM
leebee's Avatar
hello there and welcome! this is a stickied link from the top of the page for the 93 model trucks but should help you out:
http://personal.utulsa.edu/~nathan-b...fsm/index.html
lee
Old 05-14-2008, 05:37 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
I've tried compressed air when mine clogged, but that didn't work. Eventually had to use a long, heavy duty coat hanger. That did the trick. Then, finished up with compressed air and rinsed with a garden hose. No more problem.
Old 05-14-2008, 06:39 PM
Staff
DeathCougar's Avatar
You might also try draino, depending on whats in the tubes.
I would try air first, see if you can blow the crud out.
TheBFA
02-15-2020 06:55 AM
Badlander
10-10-2015 08:05 PM
mreagen
10-05-2015 04:27 PM
hiluxinargentina
09-30-2015 05:51 PM
sonorn67
09-19-2015 05:39 PM
Quick Reply: sunroof drain tube exits...WHERE???
