Sudden loss of power
I'd be cruising at 60mph, in my 91 3 liter pickup and suddenly for 1/4 second, it was as though someone had switched off the engine and then turned it back on again. Any ideas of what the problem might be
check your coil wire, if you have one.
check your transducer gap
check your distributor bearing, transducer rotor may be lifting out of range of the transducer.
check your throttle position sensor
check your maf sensor
Tacoma1313
08-17-2015 05:44 PM
