stuck without a clue
Old 03-13-2011, 10:54 AM
memphisyota's Avatar
This started when i eased off in to much water with my 95 runner (3vze) it cut off instantly. I didn't try to crank it back, i got pulled out the hole and pulled to the house. I know it sucked water into the motor. I pulled all the spark plugs out removed all the belts and put a ratchet on the crankshaft bolt and was turning it by hand. It pushed the water out the cylinders but then gets stuck at a certain point. I turned it the opposite way and it turns for a sec then gets stuck again. When ever it comes around there is a clankin noise sounding like its coming from the oil pan. Should i drop the front differental and pull the oil pan and see if its fixable or start a motor search. If it is a broke rod can i just replace that one rod. Or can i remove that one rod and run on 5 cylinders till i can afford a motor? I need some good ideas please.
Old 03-13-2011, 11:12 AM
iamsuperbleeder's Avatar
sounds like you bent a rod...
and no you can't run on just 5 cylinders by removing the bent one, lol
Old 03-13-2011, 11:15 AM
xxxtreme22r's Avatar
broken or severely bent rod gets my vote too.
Old 03-13-2011, 11:16 AM
it was just an idea its my everday vehicle. so could i just replace that one rod and be ok?
Old 03-13-2011, 11:18 AM
if you bent or broke the rod, chances are the crank journal is messed up too, if not then crank is bent as well. So no. And if you broke the rod, chance are the cyl wall is messed up as well.
Old 03-13-2011, 11:44 AM
Sponsor
Tofer's Avatar
thats what happened when i sucked water into my motor and then it would turn 9/10th of the way around in each direction but not complete the full turn...
there is the other half..
this is how i fixed it.
Old 03-13-2011, 11:50 AM
mt_goat's Avatar
That's a great solution. I highly recommend it.
Old 03-13-2011, 11:51 AM
Ok, so then it would be a waste of time to pull the oil pan hu? Then my next question is, where could i get the best price for a motor, because i love my runner and don't want to get rid of it. And what motors, if any are compatable with what i have. Or, what can i do to fix it or can it be fixed?
Old 03-13-2011, 11:55 AM
Sponsor
Tofer's Avatar
i'd pull the pan first to confirm what the issue is... but more than likely its trashed.
as far as motors swaps, the 3.4 is very popular (see picture above). the chevy 4.3, toyota 1uz, toyota 3rz, SBC, are also able to fit. there is a whole section dedicated to motor swaps. there are TONS of hours of reading
Redeth005
06-28-2018 08:16 PM
rubrsidedwn
07-07-2016 07:28 PM
spiewaker
12-16-2015 01:10 PM
Ricu_air
09-19-2015 05:35 AM
87SR5justin
09-15-2015 06:48 PM
Quick Reply: stuck without a clue
