stuck valve...
stuck valve...
allright i had a thread about 3 weeks ago about having a stuck valve, ive got the head off and the valve spring removed what els is there? the valve seems to be stuck in there, lol i know thats why its sticking, but anyways is there anything els to remove? ive got it all the way down so i cant hit it with the rubber mallot anymore, and ive tried pulling on it but no such luck.. any help would be appreciated
If you have the keepers and valve spring removed then the valve should fall out of the guide but since yours is bent its probably jamed in the guide. You could try working it back and fourth in and out, or use a small punch and drive the valve out. The valve and guide have to be replaced anyway. So you might have to take it to a machine shop.
i cant do it myself? do i need special tools or somethin? i didint really take everything off like ur supposed to intake carb n all vac lines are still hooked up i just lifted the head up enough for me to work...
spiewaker
12-16-2015 01:10 PM
