Stuck in 4 Wheel Drive
I recently acquired a 95 4WD pickup with 22RE, 5 speed manual trans, and manual locking hubs. I used the 4 WD for the first time today but can't get it back into 2WD. Tranfer case shifted right into 4WD and goes easily between 4WD High and Low but I can't move the shifter back into 2WD. Tried it with truck stopped, in neutral, and clutch depressed. Any ideas??
Perfectly normal, result of drive line binding in 4WD. What I try and do is shift out of 4WD before hitting a high traction surface and while moving straight ahead without any recent turns. This way you shift out of 4WD before the drive lines and transfer case get bound up.
06-01-2021 01:51 PM
Poncho0206
07-10-2015 06:21 PM
skoti89
07-06-2015 07:45 PM
