stronger alternator - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-02-2006, 12:59 PM   #1 (permalink)
stronger alternator
I was woundering if their is a stronger altnator for my 86 toyota pickup. I have two fog light's funning with heater and head lights and it won't Idel because to much power is taken away and turns off. So is their a bigger altnator that will bolt on or little ajustment to make it work?
Jay1 is offline
Old 12-02-2006, 01:04 PM   #2 (permalink)
EWAYota's Avatar
Send a message via AIM to EWAYota Send a message via MSN to EWAYota
Search, theres plenty of info on here about this issue. From upgrading to a GM alternator to a alternator out of a MR2 (100watts) to buying a Mean Green alternator ($$$) and much more.
__________________
DJ
1994 Pickup
22RE, Engnbldr 261 cam, 5 speed. Tires that go around and around...
Preping for SAS......
Originally Posted By Fustercluck
"Proof that Gangus did not spontaneously generate....he has relatives."
Originally Posted By Tacoclimber
"My two year old better get a job, soon..."
Reply Posted By Oly884
"I hear coal mining is a great career."
Myspace
EWAYota is offline
Old 12-02-2006, 03:25 PM   #3 (permalink)
Bill's Avatar
There are shops in Calgary that will rewind your stock alternator anywhere between stock and double, I've talked to a few guys that are happy with them.
I know you arn't going to order from Calgary, but it'd be worth phoning around some local alternator/starter shops to see what they could do for you.
__________________
86 Turbo Pickup
EB Street RV head
EB 268 Cam
V6 Brakes + MC
A340F auto ---> W56 5-spd swap
...I want a bigger turbo...
Bill is offline
Old 12-02-2006, 09:03 PM   #4 (permalink)
What year of vehicle of GM and motor size?
Jay1 is offline
Old 12-02-2006, 09:48 PM   #5 (permalink)
Staff
rocket's Avatar
Alterstart has a good reputation...
http://www.4alterstart.com/
http://stores.ebay.com/Alterstart
But most likely, your stock alternator isn't your problem. Try upgrading your ground and power wires first! It's recommended when running a H.O. alternater anyway...
http://www.the12volt.com/installbay/...TID=73496&PN=1
http://forum.sounddomain.com/forum/u...=5;t=007801;p=
http://www.yotatech.com/showthread.php?t=95850
__________________
'96-'02
gone: '92
rocket is offline
Old 12-02-2006, 10:05 PM   #6 (permalink)
tc
tc's Avatar
I had mine rebuilt by Boyle Future Tech and highly recommend it.
http://www.ttora.com/forum/showthrea...ght=alternator
Factory rated it at 60A max. At 1500 RPM, it now makes 42A, and 130A at anything over 2500 RPM! Price was very reasonable at $118 (including return shipping) and it took about a week round trip.
I'm a little concerned though, cuz you're not drawing that much current. Before spending any money, make sure all your grounds are good!
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is offline
Old 12-02-2006, 11:01 PM   #7 (permalink)
Send a message via AIM to dcg9381
How big are your fog lights?
Check to make sure your wiring is good (not cooked) at the alternator and at the battery terminal... 400 watts of lights = 30-40 amps + fan + other componets... yea.. maybe... I guess it could outrun the alternator at idle.
What does your battery voltage drop to?
__________________
http://www.22REturbo.net
dcg9381 is offline
Old 12-06-2006, 04:09 AM   #8 (permalink)
Ganoid's Avatar
170 amp drop in for $180 seems like a good deal.
High output alt on 4x4wire
__________________
1990 Xcab beast of burden
3.0 Rebuild/Precision balanced w/OS valves
Custom ported/welded Intake manifolds
Downey headers, Jacobs Ign
4" Trail Gear SAS + rear Kit
R151 + Dual cases (2.28+4.7)
5.29's,Tru Trac/Lockright on 35 BFG's
140A GM CS144 alt/Hyd assist steering
DOA Racing = $1200 lesson in who NOT to deal with
Ganoid is offline
Old 12-06-2006, 06:51 AM   #9 (permalink)
tc
tc's Avatar
Guys - for our applications, you REALLY need to focus on the low RPM output. It is possible this "mighty" 170A alternator only does 20A at idle, just like the stock one, and then you're still running out of power.
__________________
tc is offline
Old 12-06-2006, 09:19 AM   #10 (permalink)
Will one of those altnators fit in the stock mount for an 22RE?
Jay1 is offline
Old 10-01-2007, 10:19 AM   #11 (permalink)
BigWavePaul's Avatar
Question 22RE 100 amp MR2?
x2 on the "Will one of those altnators fit in the stock mount for an 22RE?"
can the MR2 100 amp unit fit on a 22re? If so, what's the part number/year of the MR2 alternator?
The write up linked above was for a 3.sl0w modded bracket
BigWavePaul is offline
Old 10-04-2007, 03:22 PM   #12 (permalink)
n4ynu1010's Avatar
Send a message via Yahoo to n4ynu1010
Alternator Problems
Are you pulling power from the fuse panel or directly from the battery ?
The best for you system would be hardwired from the battery and switched between ground , also remember to keep your wire gauge large going to these lights as smaller gauge wire would increase amp draw and decrease lamp illumination due to decrease in load voltage - Ohms law rules !
__________________
Guy
'91 ExCab Dlx Longbed/3VZE-Fast/Stock 2WD/5spd Manual
'95 GMC Jimmy SLS 4WD/4.3L Vortech/Euro Susp and Motor Package/Tow Package
F.A.I.T.H.
Forsaking All I Trust HIM
Matthew 19,20 :
19 I say again unto you,that if two of you shall agree on earth as touching anything they shall ask,it shall be done for them of my Father which is in Heaven
20 For where two or three are gathered in my Name,there Am I in the Midst of them
n4ynu1010 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Stronger CV's and Diffs NDMORETIME 95.5-2004 Tacomas & 96-2002 4Runners 11 04-16-2007 10:51 AM
Stronger Front Coils? Gerdo 99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 0 06-17-2006 11:13 AM
Stronger CV Shafts colsoncj Offroad Tech 27 02-11-2005 07:26 AM
Which IFS is stronger?? NMcruser 95.5-2004 Tacomas & 96-2002 4Runners 56 01-31-2005 08:27 PM
I thought welding was stronger Reed23 95.5-2004 Tacomas & 96-2002 4Runners 6 02-21-2004 10:49 AM
2009 InternetBrands, Inc.
