Stretched E-Brake Cable Fix
Old 08-19-2010, 08:29 AM
mountaingoat's Avatar
So after 238k miles, my parking brake is pretty marginal...it's at max adjustment, and won't hold on too much of a hill.
I didn't really want to drop $40 on a new cable right now while I'm saving for a rebuild, so I got to looking at the old stretched cable and came up with a cheap and simple fix.
1. Loosen the adjuster all the way.
2. Wrap the (now very slack) cable once around a short bolt, and clamp it on with a nut.
3. Tighten the adjuster to an appropriate amount of tension, and bingo - tight e-brake cable again!
Sure, it's a temporary fix - and my cable was so loose I ended up using two bolts, and making an additional loop in the cable. But it works, and it's nearly free!
I'll try to snap a pic later.
Old 08-19-2010, 08:39 AM
desertcamper67's Avatar
Ever try adjusting your rear brake adjuster? That helps too.
Old 08-19-2010, 08:59 PM
Yeah, the rear brakes were adjusted correctly. Sometimes the cable just gets too stretched to be effective anymore.
jasonty
41
12-23-2018 01:00 PM
yipyip45
08-06-2015 02:05 PM
priest16
15
08-06-2015 07:43 AM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
CanRunner
07-20-2015 01:29 PM
Quick Reply: Stretched E-Brake Cable Fix
