| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Stock Intake Manifold ?.
#2 (permalink) |
all i can say is if you had enough access to test fit, try that
__________________
Screw you guys I'm goin to TTORA Mods, please be mature and leave my sig alone, thanks. No, I will not be your friend. |
#3 (permalink) |
^Bump^
#4 (permalink) |
Yes. Even the intake on 83 EFI Celicas will work as they're all the same (83-88 22re)
#5 (permalink) | |
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
If you're going to go through the problem of taking off the manifold from your truck, and cleaning the manifold from a different car, which you're not exactly sure everything is going to work what with the obvious different vacuum passages and the like considering the differences between a passenger car and commercial vehicle of different years at that...
Why not just clean the manifold from your truck... which you already know works on your engine? If you can spend a day swapping manifolds, why not a day removing, cleaning and reinstalling? Oh, you're just looking for minimal downtime.
__________________
Quote:
Insomnia: it's a way of life.
#6 (permalink) |
I bought an upper intake from a 91 toyota truck for 25.00 dollars, it is the same as whats on my truck, and being from a later model truck its not angled down were the throttle body mounts on wich gives a little bit better air flow. I also bought an AFM from an 82 celica with a 5M-GE engine, it has a 3'' opening on each side and will flow more air than the stock AFM.
#7 (permalink) |
The above mod is a good idea if you can find the manifold.
Alternately, find a machine shop in your area that can "hot tank" aluminum... It's really the only way to get all that gunk out.
__________________
http://www.22REturbo.net |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Modifying intake manifold | getrdunn | 86-95 Trucks & 4Runners | 7 | 02-18-2008 10:43 PM |
| Intake Manifold | blainelukens | Maintenance & Repair Archives | 15 | 04-17-2005 10:57 AM |
| 3.4L Intake Manifold | Yosmany | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 03-30-2004 08:11 PM |
| intake manifold removal ?'s | needayota | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 02-19-2004 06:42 PM |
