Stock Height Leaf Springs
Old 02-26-2010, 08:02 AM
xxxtreme22r's Avatar
I am usually pretty good at searching for things, however this one alludes me for some reason. I have been looking for stock height leaf springs for an 87 pickup. Everything I find is either an AAL, or 2" and above. Local spring shop told me between $300 and $500 for new springs or they can re arch for about $300. Not doing that as they just us a press (cold setting process I believe) and add in another leaf. They do not re-arch the "correct way" by heating and cooling the springs.
Before anyone says it, no I don't want to do the ZUK mod to fix my saggy butt. Nor do I want to add blocks, AAL's, or longer shackles. Which won't fix the fact that the leaves are sitting on the overloads anyway. See photo below. And yes I know there is no bump stops (gonna fix that when I put in new leafs). Not sure what the original owner did with them.
Besides I don't plan on running anything bigger than a 31-32" tire. 31's on there now. If I find a cheap set of used 33's maybe. If I need the extra clearance I will just raise my flatbed a little and crank the torsions up an inch. Possibly go with a longer shackle.
Edit: Will add to this as I find them.
So far I have only come up with these:
https://www.jcwhitney.com/replacemen...x?skuId=265315 : $333.95 shipped
http://www.generalspringkc.com/index...arent=158&pg=1 : $366.21 shipped
http://www.race-mart.com/items/produ...20S-detail.htm : $321.73 shipped
http://www.carparts.com/webapp/wcs/s...0618&langId=-1 $243.21 shipped might go with these.
http://www.northwestoffroad.com/parts/2stage.html N73250 $437.95 + $120 shipping
http://www.customsuspension.com/stor...oducts_id=1209 $320 + $120 shipped when buying U-bolts
Old 02-26-2010, 08:19 AM
thedanned's Avatar
This is exactly what I want to do. I dont want to lift and I dont want the ZUK springs, I just want my 2-3 inches back! Sorry no help I havent been able to find anything either.
Old 02-26-2010, 10:51 AM
91diesel's Avatar
the easiest/cheapest way would probably just be to leave your main leaf on, and then go to the junk yard and get some leaves to make a pack out of to build up to stock height. You'll probably end up with a better pack that way anyhow.
Old 02-26-2010, 11:26 AM
abecedarian's Avatar
Check jcwhitney.com yet?
Old 02-26-2010, 11:45 AM
Teuf's Avatar
35's , sure you can, but it will be hard to maintain speed when you go up any hills. I run 33's with stock gearing and I am finally going to regear in the rear and wait till I find a front 4.88 IFS diff to drop in later.
Old 02-26-2010, 11:53 AM
wreckedrex's Avatar
I've seen them there, been meaning to do some more research to see if they're worth a hill of beans. LINK Seems like a helluva deal compared to a $300 re-arch.
Old 02-26-2010, 01:02 PM
Wrong thread ??? Or a really good hijack TEUF? lol
Old 02-26-2010, 01:55 PM
snobdds's Avatar
just out of curiousity, why are you aginst the zuk mod?
Old 02-26-2010, 01:56 PM
Philbert's Avatar
Epic Hijacking...
Old 02-26-2010, 02:01 PM
Staff
DeathCougar's Avatar
He didn't hijack, he responded to a post that I deleted from another member who DID hijack the thread. He had already hit the reply button as I was deleting it.
Carry on!
Old 02-26-2010, 02:06 PM
Teuf's Avatar
oops just saw that, i need sleep, sorry
Teuf's Avatar
OOOOOK death , so i am not crazy.......
Old 02-26-2010, 03:36 PM
Spoon7's Avatar
I was able to find stock height rear springs for my saggy 89 4runner manufactured by Dallas spring. You can't buy from them direct but your local spring guy can. $140 per spring sounded good to me for how much time I spent trying to solve this problem. Mine are on order and Ill be running them in a week if you want to wait to see how I like them. Good luck!!
Old 02-26-2010, 04:55 PM
phildelfino's Avatar
I bought mine from JCWhitney and can tell you that they are too stiff. I would buy them again though and mix and match till I got a good pack. (knowing what I know now-hindsight).
Old 02-26-2010, 05:02 PM
neockder's Avatar
what about increasing shackle length? Although stockers on my 4Runner are pretty long already..
Old 02-26-2010, 05:08 PM
4banginRunner's Avatar
I'd say get some 2" OME springs and give the t-bars a few cranks (or buy my BJ spacers ).
http://www.rocky-road.com/4runner.html
Old 02-26-2010, 05:09 PM
stock should be a 4" shackle
Old 02-26-2010, 05:37 PM
neockder's Avatar
Hmm.. maybe orig owner put longer ones in! Look like 6ers to me.
Old 02-26-2010, 06:28 PM
peow130's Avatar
i did AAL to get back up to stock-ish.
i'm about 1" over in the rear, but i fixed that in the front with a tbar crank..
AAL's work, mine were off a used truck so they're a bit more forgiving.
Old 02-26-2010, 06:36 PM
yoder519's Avatar
x2 on this. i woudl go to a junkyard, get a set of used rear springs, prob cost you 50-100 bucks, and make your own spring pack. or maybe buy some 2inch lift springs, and remove a leaf? jsut spit balling here
Quick Reply: Stock Height Leaf Springs
