stock gear ratio
Old 09-24-2009, 01:25 PM
Oldmans4x4's Avatar
stock gear ratio
I tried searching, maybe I just haven't come to the right thread yet but I am trying to find out the stock 3.0 v6 sr5 thirds gear ratio for a 91 truck.
Anyone willing to help with quickie would be greatly appreciated. Thanks!
Old 09-24-2009, 01:47 PM
bain's Avatar
what was factory tire size? or you can jack it up and spin the wheel and count the drive shaft rotations...
Old 09-24-2009, 02:26 PM
Kiroshu's Avatar
well you could take apart the trans count the gear teeth on the gears on the counter shaft and main shaft and do your math.................... but thats too much work..... i'm not sure off the top of my head.... i know overall raito is 4:10 i believe.
Old 09-24-2009, 03:27 PM
peow130's Avatar
Auto or Manual?
Stock tire size?
Old 09-24-2009, 03:33 PM
Tubbyfatty's Avatar
I dont know about you guys but im not going to sit under my truck and count rotations.
http://www.brian894x4.com/Gearratiosanddiffs.html scroll down and read lol.
Old 09-24-2009, 03:34 PM
Staff
DeathCougar's Avatar
Here are the possible options from 1991:
4.10 5sp manual
4.56 Automatic
These are assuming the diffs are still 100% stock. Could have been changed before, best to take the diff out and check
Old 09-24-2009, 03:35 PM
Staff
And what happens when the gear ratio has been changed by a previous owner?
Old 09-24-2009, 05:21 PM
Tubbyfatty's Avatar
Didnt he say "im trying to find the stock ratio"?
But if the PO changed it, then you have to count lol.
Old 09-24-2009, 05:30 PM
Staff
This assumes the truck is 100% stock from the factory. Unless a person is the original owner, how can one be sure? There are many mods to my truck that would appear stock to the unknowing eye.
Old 09-24-2009, 05:39 PM
highridinyota's Avatar
gear code on door .should read something like at/mg292 for example. with the g indication being the diff size ex.8 in.the 29 being the ratio such as 4.10 and the 2 standing for 2 pinion diff
Old 09-24-2009, 05:41 PM
4.10 5sp manual
4.56 Automatic
some truck were sent out of the factory with 4.30 gears for the v6 manual set up
Old 09-24-2009, 05:44 PM
Staff
Close, it would be A/TM for Axle/Transmission. You are correct, it will be G292 or something similar
Not in 1991 they didn't. In a 4wd, the only options were 4.10 and 4.56
Old 09-24-2009, 05:50 PM
waskillywabbit's Avatar
Toyota Gear Ratios
Old 09-24-2009, 05:52 PM
mrvoodoodaddy69's Avatar
the only way to be positive is to pull the differential and count. But really you can figure it out, and be pretty confident. Take truck for a drive and watch tach and speedo when you are in 4th gear manual, 3rd for auto at 55 MPH and get you tire size and check out this chart. http://jeephorizons.com/tech/rpmchart.html
Old 09-24-2009, 06:56 PM
85excab's Avatar
pull the rear drive shaft off the rear 3rd member, and look at the color of the paint on the pinyon. quick and easy
Code:
Ratio Ring/Pinion Color Crawl:Ratio
3.42 ...42/12... Purple ...31:1
3.90 ...39/10... Red... ...36:1
4.10 ...41/10... Pink.. ...37:1
4.11 ...37/09... Orange ...37:1
4.30 ...43/10... Blue.. ...39:1
4.37 ...35/08... Green. ...40:1
4.56 ...41/09... Yellow ...41:1
4.88 ...39/08... White. ...44:1
5.29 ...37/07... None.. ...48:1
5.71 ...40/07... None.. ...51:1
Old 09-24-2009, 09:09 PM
Oldmans4x4's Avatar
My old man wasn't the original owner, he bought it over a decade now. I don't think he's changed anything because he's not the type. I don't know if the previous owner did though. Looks stock and has been that way ever since my old man bought it. It is an Automatic, running on 31s with tow package.
I will try some of the above mention. Thanks again everyone : )
Old 09-24-2009, 10:08 PM
Oldmans4x4's Avatar
Another question while we're at it, no matter what gears or third member, all inner rear axles are the same right?
Old 09-24-2009, 10:28 PM
camo31_10.50's Avatar
you dont have to pull the third member out just to check the ratio DC????
you can do the "rotate tire and count DS rotations" method right??????
hell thats how i find the 4.56 and 4.88 diffs at the junkyards in Toyota's...
if its auto and was on 31's from the factory then it most likely has 4.56's
Old 09-24-2009, 10:59 PM
85excab's Avatar
am i talking to the wall, does no one else know about the colors?
is this a hidden toyota secret?
Old 09-25-2009, 07:54 AM
Jay351's Avatar
Pink is 4.10.
I don't know the rest, get off yer lazy rear and check yourself.
My 91 came with 4.56's. I did the spin tire method to find that out, since my cab is from a 90 p/u with a 22re...
Quick Reply: stock gear ratio
