| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Stock flywheel weight?
#2 (permalink) |
I weighed mine using my bathroom scales. 24 lbs.
__________________
1986 22R 4X4 pickup. Currently rebuilding the engine. |
#3 (permalink) |
I weighed mine with fishing scales, 24lbs too.
That was before i shaved 10lbs off....
__________________
Targetnut don't talk about it, just do it! Precision Import Service '93 2WD 22RE, Ported w/os valves, custom intake manifold, crane cam,Megasquirt, 295cc injctrs, Supra fuel pump, adj fuel pres reg, 70mm throttle, LCE header, V6 Taco cat, 14lb flywheel, Kevlar clutch, W58 and short shifter, 4.10 gears w/Truetrac, drop spindles and blocks, 245/50-16 Yokos on 16x8 wheels, 4WD fenders, bumper, and valence, skinned tailgate |
#4 (permalink) |
How did you go about shaving off 10lbs?
#5 (permalink) |
If you really want a lighter flywheel, the LCE 16 lb billet is the way to go. It probably won't buy you any noticeable performance gain....but you'll feel lighter!
TJMWO, gNARLS. |
#6 (permalink) |
Yeah we were looking to go lighter, but dont want to go to light, so that might be perfect.
#7 (permalink) |
one of my buddies had a machine shop drill the whole way around the outside edge of his flywheel off the clutch contact surface to lighten it up. Make sure they have the capability to balance it too... lighter does rev quicker!
__________________
The Rat TuRD- 86 turbo'd xtra cab on regular cab frame, SAS,w/38's. build pics-http://viewmorepics.myspace.com/index.cfm?fuseaction=user.viewPicture&friendID=149 378773&albumId=1402134 The baby hauler- 01 Lexus IS 300. She claimed it. The toy hauler- 00 Tundra Limited, 4.7, 2wd. The 4 seater beater- 91 4runner w/3vze. What was Toyota thinking? R150 5 speed swap, so far. Toys- 06 Triumph Daytona 675, 05 Honda Rancher 4X4, and still looking for my stolen 2000 Suzuki RM 250 $500 reward. |
#8 (permalink) |
It wasn't easy,,,,or pretty.
First I turned the backside with a brake lathe. That was about 5lbs Then I use a drill and a die grinder to cut out the spaces between the clutch mounting holes. I made an adapter and balanced it on a wheel balancer. And it is remarkable how much it improved responsiveness. I'ts didn't make it into an instant drag car but it was a very noticeable improvement.
__________________
| Tags |
| 1986, 22r, 22re, 4x4, billit, brake, flywheel, is300, lathe, lbs, lce, shaving, stock, toyota, weight |
