steering wheel still shakes after frontend work
im still getting a pretty good amount of shaking in the steering wheel.
i've replaced the following parts
1.pitman arm.
2.idler arm.
3.steering stablizer/shock.
this fixed alot of my inital steering wheel vibration but i still have some, and don't think it's normal. what else or where else should i look.
balljoints? tie rod ends?
wheel bearings....
1.pitman arm.
2.idler arm.
wheel bearings....
i will head to this shop and have my tires balanced, but i recently had the driver front balanced because i knew for a fact the weight wasn't on the rim
when i replaced all the parts i got the front aligned the guy said everything was spot on. i don't think i have the printouts... errr.. i wouldn't think it was a warped rotor, that would only cause shaking when stopping.
so the only things i can think of is replacing the tie rod ends, and balljoints before i take my truck to toyota to get the steeringrods replaced because of the recall. this will give me a free alignment. =) lol
might as well use the recall to my advantage.
GreenLion
06-07-2021 10:49 AM
YotaGreenhorn
06-27-2015 07:00 AM
