steering stabilizer ?'s
I ordered a set of pro comp ES3000 shocks and steering stabilizer.
I was wondering since i haven't found any pics of what i am looking for if someone had some pics of the steering stabilizer kit installed on an 87 or similar pickup. With or without lift.
I looked at the install instructions on pro comp but something tells me the pic if of a different year. Mine right now has the factory steering stabilizer in it. I am pretty sure i ordered the one with the bracket assembly not the direct bolt in as well.
Thanks.
PS doesn't have to be the pro comp setup either.
Thanks.
ah it's not too terribly diffifult to remove, my original one wasn't anyway; the front shocks were more difficult than the stabilizer
I'd assume the kit has the same setup as my Monroe stabilizer; just a tapered bolt that fastens to the drag link (or center link, whatever you favor calling it ), and then the new stabilizer just slides onto that new mount, and you're good to go
Welcome to YT by the way!
well a steering stabilizer is just that it stabilizes the steering if you have a bad one everytime you hit good sized pot holes you'll get "bump steer" and the steering wheel goes left or right, and the stabilizer corrects this
for S&G's... here's the one on my 2wd:
Notice the stud mount to the frame compared to the eye mount on iamsuperbleeder's post.
Basically, they dampen any sudden motion in the steering linkage. Even well maintained and perfecly aligned vehicles are subject to 'bump steer' from potholes, irregular / uneven surfaces and things. And not sure about anyone else, installing the one in the 2wd truck even helped with tracking the grooves on the freeways.
I was assuming this is waht it did, but being new to trucks, you never know. Yeah, Im all good.
I hardly noticed a difference after replacing the 22 year old stabilizer on my truck with a new pro comp unit. There are probably better ways to spend the money, but heck, it was only like $30, so not a big deal.
In case no one has told you, get a pickle fork and a big hammer to get the old one off. Go to town with that hammer!!
is bleeder's stabilizer mounted backwards?..
im pretty sure the body of the shock should be mounted to the frame..
thats how it is on my '86 and every other truck i've ever seen..lol
guess it really would matter though would it..it'll still do the same thing
Camo your right but I have seen them mounted both ways when they come in for the SSC. I don't see how it would have any negative effects.
thanks guys this is the info i was pretty much looking for. Already got a pickle fork, two of them actually. I gold plated them because of they are worth. If anyone has ever tried to do a front subframe on an E34 BMW before knows what I am talking about.
I see what you mean and that's what the confusion was that led to this post.
If you look at the image they have in their instructions then you can also see the stock stabilizer still installed ?????
Here is what the instructions show for this kit:
P.S. Where's your left tie rod end bleeder? Looks like its missing.
and yeah I guess that side was missing at the time of that pic; this was during my entire front-end rebuild
The reason I am asking - I'm interested in doing an OM617 diesel swap. Unfortunately, the swap requires the stabilizer to be deleted for clearance. I'm just curious if that will be a deal-breaker. I have heard you can just run a little extra positive caster, and the truck will want to track straight down the highway. Your thoughts?
kawazx636
10-06-2021 03:03 PM
live4soccer7
05-11-2016 06:52 PM
scott90
10-04-2015 09:21 AM
