Steering Problem
Old 12-26-2011, 04:16 PM
Guardian_Saint's Avatar
Steering Problem
This recently just started to happen. When I make a left turn. I can fill a slack or sounded like a loose bolt on the driver side tire when I turn to the left. I am thinking bearing or cv boot? Any thought it may be? THAnks a bunch...
:jessica:
Old 12-27-2011, 01:16 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Check your steering linkage, pitman arm, etc. Have it up on stands so you can get all of the tension off and really check for slack.
Old 12-27-2011, 04:46 PM
Thanks thook. I see if that may be the cause. It ussually happen when I get it some accelerate while turning left. It felt like it jump over or sliding sound that is when I can fill the slack for a second.
Old 12-28-2011, 09:23 AM
thook's Avatar
Righto. Last time I had symptoms like that, I had a bad steering idler arm. Of course, the vehicle also tended to pull to the right a bit when driving straight. Anyway, that's why I suggested looking at the pitman and linkage.....since your symptom seems associated on the left side.
Yotadawgjr
10
08-23-2015 10:51 AM
terminator
07-27-2015 07:13 PM
keithporter83
07-24-2015 07:37 AM
voiddweller
07-15-2015 03:56 PM
Quick Reply: Steering Problem
