steering gear box?
steering gear box?
there is play with my steering. i had someone play with steering wheel while i looked at the column(?) and it moves accordly to steering wheel but the wheels dnt move. i lifted front end to see if wheels had play and they didnt.
it seems to be in the gear box. i looked online and it seems expensive to replace. could something just be loose and needs to be tightend in there? or am i screwed and have to get new stuff?
Something to try before replacing any parts, is tighten the steering gear backlash. Looking at the steering gear from the top in the engine compartment, you should see an adjustment screw with a lock nut (near the center of the steering gear). Loosen the lock nut, and turn the adjusting screw clockwise to tighten the steering freeplay (or counterclockwise to loosen it). Adjust it in small increments (1/4 turn at a time) and check steering wheel freeplay between each adjustment. When it feels OK, hold the adjusting screw from turning, and tighten the lock nut. Hop in the truck and make sure steering is still smooth, with no binding from lock to lock. NOTE: If you tighten it too much, it will decrease the truck's ability to auto-straighten the wheels when you come out of a turn (similar to if there's not enough caster in your alignment). If you notice this, turn the adjusting screw counterclockwise a bit to fix it.
Steering Gearbox Play
Yes , tighten the screw but don't go too tight , if you tighten the screw properly it won't hurt a thing and will resolve your problem though you may experience it being a bit snug to the right and left steering (or maybe a tad of pump noise) when you do until you use it for awhile , the previous post is a very good explanation
2WD
http://personal.utulsa.edu/~nathan-buchanan/93fsm/steering/7manualge.pdf
4WD
http://personal.utulsa.edu/~nathan-buchanan/93fsm/steering/8manua.pdf
If you open this PDF for your gearbox you will see on both first pages a breakdown , the nut and screw (so to speak) are plain to see in both pics , if you look at the top of the gearbox (whether 2 or 4WD) for the plate with 4 bolts (one at each corner) ...............and right there in the middle of that plate is the locknut and adj. screw - loosen the nut and turn the flathead slot in the end of the adj.'ing screw clockwise to remove any play you may have from wear and tear , this adj. generally removes free play , what would be between your steering wheel and the pitman arm , I was looking thru FSM and here is another page from it for the free play adjustment in regards to service and fluid level :
http://personal.utulsa.edu/~nathan-buchanan/93fsm/steering/3onvehicl.pdf
jerusry
10-19-2015 05:28 PM
terminator
07-27-2015 07:13 PM
justdifferentials
Just Differentials
07-22-2015 08:26 PM
crashburnoveride
07-10-2015 06:39 AM
